hello can anyone tell me if kodi 18 beta 2 solves the problems of the dts passthrough not working?
It works if you have a proper device
(2018-09-11, 14:37)Martijn Wrote: [ -> ]It works if you have a proper device
Im sure you meant device that conforms !!!
I have a HIMEDIA q5 pro .... is a good device but unfortunately the beta 1 did not work well with DTS but only the beta 1 shitty version
Wait, so you already knew that you needed to use the shitty version, but you didn't look for a beta 2 shitty version?
Just remember, shitty hardware = shitty version
