2019-01-28, 11:57
2019-01-28, 12:00
2019-01-29, 04:05
So it just doesn't update on my Nvidia Shield, and I'm unable to manually refresh a movie (I noticed a movie that was incorrectly scrapped and tried to manually refresh it with the refresh button did nothing, no dialog). I created a debug log but it was too big to paste, in fact half of it was too big to paste. Here's the first part:
https://paste.kodi.tv/bezumeroyi.kodi
before this starts:
19:54:23.506 T:155293631728 DEBUG: This query part contains a like, we will double backslash in the next field: nfs://nasislike/
for like 10,000 lines (with slight variations)
Here's the end:
https://paste.kodi.tv/okewokezem.kodi
before this starts:
Here's the end:
2019-01-29, 04:07
Also, I forgot to mention: I was able to update my Library in my Windows 10 machine (which is actually running 17.3, not 17.6 like the Nvidia Shields are)
2019-02-03, 19:38
My issue is solved. After the update, the refresh button wasn't even present. I realized it was as simple as Universal Scraper not being installed...doh
2019-07-02, 23:38
I just wanted to add that mine was resolved too. The option to scrape based on tag data rather than filenames had somehow been turned on, and as none of mine have tags they couldn't be identified. Once turned off it went back to working perfectly.
2020-11-15, 00:57
i have the same problem
when adding a files , and library is not updated anymore
2020-11-15, 02:08
2020-11-15, 15:05
I will link a debug log
But it looks like the TV-shows playlist is not updating anymore
i removed the playlist and the link to the directory, so a complete library update must be done
But now i see only the covers no content of the tv shows anymore
I also added a movie at a other playlist
and those are normally added when i update the library
so looks there is a problem with the TV shows
2020-11-15, 16:16
http://ix.io.2EfC
It this log what is needed to check ?
Strange i kan add files to de playlist,
Kids
Movies
After updating library they are at kodi
but adding file of a new playlist of
Series
noting is added to the library , even when i update it
names of files are like
Vikings.S06E10.mkv
normaly it worked fine, but now it is not working anymore
Kids
Movies
Series
Vikings.S06E10.mkv
2020-11-15, 19:21
looks like im doing someting wrong
log file is not uploaded to http://ix.....
this one is working
http://ix.io/2Ehc
and how to enable Component logging which captures the scrape the a playlist
this one is working
http://ix.io/2Ehc
2020-11-15, 21:07
@NiekN
TheMovieDB scraper v3.5.5 is still broken.
Please switch over to this scraper... https://kodi.wiki/view/Add-on:TMDb_TV_Shows
2020-11-16, 13:51
@Karellen
OK the scraper is broken v3.5.5. But only for TV-shows?
For a working solution i should install an other scraper , from you link
But if im correct that is a add-on which must be new installed
I have to check if i can get it working(im not so experienced) , but i could also wait . maybe it is fixed next week or so ?
but thx for helping me..
2020-11-16, 19:23
Im using themovieDB.org for movies, kids-movies and TV-Shows
version 3.5.6
now in installed the add-on TMDb TV-Shows 1.1.18
And used it at TV-Shows, now it is working again
But is this a temporarily solution
What is the difference between these scrapers ?
version 3.5.6
2020-11-16, 21:12
(2020-11-16, 19:23)NiekN Wrote: [ -> ]version 3.5.6This is the original scraper which is based on XML Regex
(2020-11-16, 19:23)NiekN Wrote: [ -> ]now in installed the add-on TMDb TV-Shows 1.1.18This is the new scraper based on Python. It is still in testing but has already become the default tv show scraper in v19.
