Full Version: Movie Library not updating
Pages: 1 2 3
Hi everyone,
I have the following problem I hope someone can help me with. I'm running Kodi 17.6 on my nvidia shield (Android TV 7.1.) and I cannot update my movie library anymore. When I choose "Update Library" it just loads for a split second and then it ends, no scan happening at all.
Debug log uploaded below.
Edit: https://paste.kodi.tv/puvoledivi
Thanks and cheers
Ferdi
What is your video source on the Shield, UPnP only, or something directly via SMB or NFS..?
Are your scraper addons all updated?
I'm just using UPnP as source and scraper addons are all up to date.
The forum moderators have determined that Banned_addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
If you are using FreeNAS, and updated to 11.1-U6, they changed SMB to v2 or v3 and got rid of support for SMB v1 (which is the only protocol that the Nvidia Shield Supports). There is a fix (search for SMB issues with 11.1-U6) that you can apply to your NAS. Again, assuming you are using a FreeNAS.
No, I'm using a Synology NAS and the share is added via UPnP. Any other ideas?
(2018-09-11, 22:01)GreenMan85 Wrote: [ -> ]Any other ideas?
Not until you remove the banned add-ons and submit a new log.
I just did, please see edit in my original post.
Ok, thanks.
You cannot scrape uPNP sources into the library. But I am surprised that you indicate that you could previously. Are you sure you were using uPNP?
xml:
22:07:33.841 T:187830719728 NOTICE: VideoInfoScanner: Starting scan ..
22:07:33.841 T:187749967088 DEBUG: CAnnouncementManager - Announcement: OnScanStarted from xbmc
22:07:33.842 T:187749967088 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnScanStarted
22:07:33.842 T:187830719728 WARNING: Process directory 'upnp://0011323f-9992-0011-9299-92993f321100/33%2413850/' does not exist - skipping scan.
22:07:33.842 T:187830719728 WARNING: Process directory 'upnp://0011323f-9992-0011-9299-92993f321100/33%245/' does not exist - skipping scan.
22:07:33.842 T:187830719728 WARNING: Process directory 'upnp://0011323f-9992-0011-9299-92993f321100/33%246/' does not exist - skipping scan.
22:07:33.843 T:187830719728 WARNING: Process directory 'upnp://0011323f-9992-0011-9299-92993f321100/33%246470/' does not exist - skipping scan.
22:07:33.843 T:187830719728 WARNING: Process directory 'upnp://0011323f-9992-0011-9299-92993f321100/33%246472/' does not exist - skipping scan.
22:07:33.856 T:187830719728 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
Ah ok, that is good to know. No, previously I added the share via SMB. But that is not working anymore. When I try to add a share via smb://diskstation I get an error Operation not permitted.
Ok. You need to ensure you using SMB v2
You cannot browse SMB networks. You need to enter the full and correct address as shown in the image below...
More screenshots here... https://forum.kodi.tv/showthread.php?tid...pid2736119
It is still not working. I typed the full IP address and the correct path. Always "Operation not permitted". I played around a bit with the smb settings on my Synology and when I changed "lowest-smb-protocol" to smb2 it still doesnt work, but now I get the error Connection timed out.
You ever solve this?  this is 95% the same as my issue (synology, nvidia shield, Movie Library not updating) but I'm sharing with NFS...
edit: I'm sorry I never know whether it's better protocol to bump an older but similar thread or just start a new one.  Here's my log: https://paste.kodi.tv/adecifamig.kodi I'll hang tight for a few minutes but maybe then start my own thread...
Can you enable Debug mode in SEttings>System Settings>Logging and resubmit. Are those path substitutions meant to be commented out?
(2019-01-26, 16:33)seth.feinberg Wrote: [ -> ]You ever solve this?  this is 95% the same as my issue (synology, nvidia shield, Movie Library not updating) but I'm sharing with NFS...
Interestingly, my library has suddenly stopped updating too. Using NFS shares as well. My watched statuses work, and my scraper is running and seeing the new content but nothing is getting added to the library. Only started happening in the last 48 hours or so. I need to check whether something has changed.
Pages: 1 2 3
