2018-09-12, 10:13
Hi there,
I have a "RecentMovie" Widget on my homescreen, which autoscrolls through the items (shown as a Poster) in that list. For now the background/fanart switches every time the widget scrolls to another item. But instead of a "simple" switch I would like to autoscroll through the fanarts in the same rhythym as the widget autoscrolls through the items.
The current fanart switch works with:
So since Autoscroll for an image only works within a Container (as far as I know?) I tried following:
Unfortunately that doesn't work. I guess its because I useing the content from another container within a different container!? Is there any solution for what I trying to achieve or is it not possible?
xml:
<control type="image" id="32117">
<include>FullScreenDimensions</include>
<aspectratio>scale</aspectratio>
<texture background="true">$INFO[Container(11011).ListItem.Art(fanart)]</texture>
<visible>Container(9000).HasFocus(10) + !Skin.HasSetting(hide_fanarthome)</visible>
</control>
xml:
<control type="wraplist" id="32117">
<posx>0</posx>
<posy>0</posy>
<width>1920</width>
<height>1080</height>
<viewtype label="List">List</viewtype>
<autoscroll time="15000" delay="15000" repeat="15000">Container(9000).HasFocus(10)</autoscroll>
<orientation>horizontal</orientation>
<preloaditems>2</preloaditems>
<itemlayout width="1920" height="1080">
<control type="image">
<posx>0</posx>
<posy>0</posy>
<width>1920</width>
</control>
</itemlayout>
<focusedlayout width="1920" height="1080">
<posx>0</posx>
<posy>0</posy>
<width>1920</width>
</control>
</focusedlayout>
</control>
