2018-09-13, 01:54
Hello,
since I updated from KODI 17 to 18 Beta2, the power saving feature stopped working.
For example: set Settings -> Interface -> Screensaver to "Dim after 5 Minutes" and Settings -> System -> Power saving -> Put display to sleep when idle to 10 minutes.
After 5 minutes the screen dims, everything is okay. After 10 minutes the screen goes black for 1 or 2 seconds and the switches back to full brightness. With KODI 17.6 it worked without problems.
Does anybody have the same behaviour and has found a solution?
Thanks in advance!
Thanks in advance!
