2018-09-18, 00:28
Solved: Fixed with kodi-20180924-3af76f1a-master! Thank you very much.
Since kodi-20180913-e313d39f (or kodi-20180912-ed0618f3) and every follwing build up to now the menu TVShows cannot be opened anymore, it simply freezes with an empty screen. Movies and music works.
The last version I installed (kodi-20180911-ae396e22) worked fine.
Tested devices
Fire TV 4k (arm64 build)
Samsung Galaxy Tab S3 (arm64 build)
Full Debug-Log
https://paste.ee/p/WSCjU
End of Debug-Log - at the last line Kodi freezes, the build from Sept. 11 works without problems!
Tested devices
Full Debug-Log
DEBUG: ------ Window Init () ------
DEBUG: Alloc resources: 0.01ms (0.01 ms skin load)
DEBUG: Thread Timer start, auto delete: false
DEBUG: Thread Timer 547113399376 terminating
DEBUG: Unfocus WindowID: 10016, ControlID: 9002
DEBUG: CGUIWindowManager:: PreviousWindow: Deactivate
DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
DEBUG: FreeVisualisation() done
DEBUG: CGUIWindowManager:: PreviousWindow: Activate new
DEBUG: ------ Window Init (Settings.xml) ------
DEBUG: Window Settings.xml was already loaded
DEBUG: Alloc resources: 0.92ms
DEBUG: CXBMCApp::onReceive - Got intent. Action: android.intent.action.BATTERY_CHANGED
DEBUG: Unfocus WindowID: 10004, ControlID: 9002
DEBUG: ------ Window Deinit (Settings.xml) ------
DEBUG: ------ Window Init (Home.xml) ------
DEBUG: Window Home.xml was already loaded
DEBUG: Alloc resources: 3.15ms
DEBUG: Unfocus WindowID: 10000, ControlID: 9000
DEBUG: Activating window ID: 10025
DEBUG: ------ Window Deinit (Home.xml) ------
DEBUG: ------ Window Init (MyVideoNav.xml) ------
INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
DEBUG: Skin file /data/user/0/org.xbmc.kodi/cache/apk/assets/addons/skin.estouchy/xml/MyVideoNav.xml loaded in 115.05ms
DEBUG: Alloc resources: 116.44ms (115.43 ms skin load)
DEBUG: CGUIMediaWindow::GetDirectory (videodb://tvshows/titles/)
DEBUG: ParentPath = [videodb://tvshows/titles/]
