2018-09-18, 14:15
So I had to reset the router and the NFS IP addresses on my WD Mycloud single bay reset so I had to remove all sources, clean library and re add folders.
It didn’t clear completely so I tried uninstalling the app. It didn’t fully uninstall and it’s still there. It ended up resetting and working again but now the app is not working again.
I did a full shutdown and cleared MAC address (of which I heard can sometimes help with issues) and the app doesn’t work. It keeps on saying error 0x80070490.
I don’t know if there is a way to fully reset the Xbox but I don’t want to because there is a lot of stuff I’ve set up on it. Uninstalling it doesn’t work either as the app still stays there.
Any thoughts on why it stopped working or how I could fix it?
