2018-09-20, 23:59
Source Code
https://k.slyguy.xyz/.repo/plugin.video....source.zip
Info & Install Instructions
https://www.matthuisman.nz/2018/12/dstv-now-kodi-add-on.html
(2020-04-13, 08:50)Leroyzaiya Wrote: [ -> ]Hi Matt
I tried that but still no luck
(2020-08-03, 17:08)shafiek1706 Wrote: [ -> ]Good day
Can anybody tell me why my DSTV NOW on Kodi doesn't show me the premium bouquet, it shows the Compact bouquet.
It just all of a sudden started showing the compact bouquet, the subscriber do have the premium.
(2020-06-05, 18:28)Vans Wrote: [ -> ]Hi All,
Please help in getting Dstv Now to work on my Android Device with Kodi.
I have downloaded the latest Kodi from playstore version 18.6. All works.
I have downloaded the latest zip file for Slyguy 0.0.2 which I belief is the repo version.
I have Dstv Now and Showmax downloaded, it opens and I can see all the shows, although when clicking on any show and choosing the video quality nothing happens. I have tried all video options and bypass nothing.
IT mentioned the widevine not possibly be on the correct level, I belief my android is on level 1.
I have seen in some posts they have mentioned if you change the esn, but where is this and how can I change the widevine from level 1 to possibly 3?
I belief if this is sorted the Dstv Now and Showmax should work.
Any help would be truly appreciated.
My device details :
Device name Roik10
Android : version 1 nougat 7.1.2
Supported ABI :arm64-v8a armeabi - v7a armeabi
Build :rk3399_firefly_mipi_box_userdebug 7.1.2 NHG-47k eng. microcity. 20190402.162524 test keys.
(2018-09-20, 23:59)matthuisman Wrote: [ -> ]Hello,
Source Code
(2021-05-14, 09:14)AshipaEk0 Wrote: [ -> ]Sure does.(2018-09-20, 23:59)matthuisman Wrote: [ -> ]Hello,
Source Code
Does this addon work on kodi 19?
