Where does kodi keep the list of top 100 songs played, I would like to export this as a playlist if possible. Thanks for all your hard work.
I know kodi can generate a playlist with recent song you listen, but I don't know if is possible to download the songs.
I don’t need to download them, they are coming from my music library on my server, I was just interested in the playlist it makes, and being able to export the playlist.
Navigate to the "top 100 songs" and play it (key <p>) or if you use "play next song automatically" select the first song. That should load the list into the now-playng music playlist. Open the music playlist window and in the side/top menu (depends on skin) there should be an option to save the playlist. That will create an m3u playlist file in your userdata music playlists folder.
scott s.
