2018-09-24, 20:09
2018-09-24, 22:22
That shouldn't be made by an external plugin though. Btw i will try it, thanks
2018-09-25, 10:53
(2018-09-24, 22:22)Haris1977 Wrote: [ -> ]That shouldn't be made by an external plugin though. Btw i will try it, thanksWell i ve download it and i only selected "automatically remove orphaned subtitle files" from housekipping tab. Doesn t work though.
2018-09-25, 11:20
Oh..it works !! It just happens upon the next reboot! Thanks man
2018-09-25, 14:32
(2018-09-25, 11:20)Haris1977 Wrote: [ -> ]Oh..it works !! It just happens upon the next reboot! Thanks manIt is run periodically every 6 hours unless there's a video being played.
2018-09-25, 14:45
But for me it worked after every reboot. Is this normal? I tried it many times to see if it works and it does.
2018-09-25, 14:52
2018-09-25, 15:21
And I've moved it into the subtitles support section to finish the job up...
2018-09-25, 22:07
Sorry, you are right
2020-07-24, 20:00
No matter what i do i cant get it to clean subtitles of ads and unwanted matter. Is this supposed to do that ? If yes can someone suggest the settings ?
2020-08-01, 17:43
(2020-07-24, 20:00)extremeaudio Wrote: [ -> ]No matter what i do i cant get it to clean subtitles of ads and unwanted matter. Is this supposed to do that ? If yes can someone suggest the settings ?
Hi. It should work almost out-of-the-box unless there's some issue. If you enable debug level logging, set it to separate file for clarity, the plugin will log much everything it does.
