2018-09-27, 17:34
Hi all,
I've been busy all day trying it fix this problem. I have a 2TB HDD connected to my router with USB 3.0.There are around 200 movies on this disk. I connected my android TV to my router with cable.
When I add the HDD to the kodi video file list everything goes smooth. I setup the "MovieDatabase" scraper to make everything look nice and good.
I see everything, I can look around in my HDD though kodi. But as soon as I try and play a movie it gives me the error: "One or more items failed to play, check the log files"
So I check the log files, but there are never any logs added. Except the "kodi started correctly" log.
I connected my HDD to kodi using SMB without authentication (That's how I setup my HDD to my router so i didn't have to enter any credentials if I want to access the HDD from my laptop)
I dont want to use UPnP because that doesn't work with the movie scraper.
Also tried to connect with NFS but that does nothing. Just loads for a second and then nothing.
I've been trying everything. Reinstalled Kodi 5 times already. Added the HDD again and again. Let it re-scan everything. But still nothing works.
Please help. I'm about to give up.
Ahh yeah, my laptop has exactly the same setup with SMB to the router wireless and it works flawlessly.
Thanks in advance
Kevin
Thanks in advance
Kevin
