2018-09-28, 01:09
Are there any guides to achieving PERFECT playback on Kodi 18 running Ubuntu 18.04 desktop version as the OS, on systems with VAAPI graphics? I am trying to minimize or preferably eliminate dropped frames.
(2018-09-28, 07:02)Klojum Wrote: [ -> ]VAAPI for which hardware? Intel or AMD? We are not keeping track of which hardware every single Kodi forum user has...Intel.
(2018-09-28, 12:48)FernetMenta Wrote: [ -> ]https://forum.kodi.tv/showthread.php?tid=231955Thanks but that is for AMD and also it is horribly complicated. I was hoping that there might be Intel-specific instructions that are simpler than those!
(2018-09-28, 17:32)FernetMenta Wrote: [ -> ]This thread started 2015, long before we supported VAAPI for AMD.If you are talking about the thread at https://forum.kodi.tv/showthread.php?tid=231955 I am looking at the first post there, which has way way more than a couple of commands. Is there some other post I should be looking at? And anyway that thread does not really seem relevant to what I asked for two reasons, first because neither Kodi 18 nor Ubuntu 18.04 were around yet when that was written, and second because it's specifically for an AMD processor which is not what I have. If there are a couple of commands in those instructions that would be relevant to users of Kodi 18 and Ubuntu 18.04 on machines with Intel processors and VAAPI graphics, I would really appreciate it if you could show me which ones those are. Is it possible that maybe you sent me the wrong link?
What is complicated with this? You just need to copy/paste a couple of commands.
(2018-09-29, 08:23)FernetMenta Wrote: [ -> ]Make sure you have TripleBuffer disabled in xorg.conf. This is enabled by defaultThank you for that tip but I am really confused now. I cannot seem to find xorg.conf in Ubuntu 18.04. I know that Ubuntu supposedly went back to xorg, and IIRC xorg.conf used to be in the /etc/X11 directory in older (pre-Unity) versions of Ubuntu but it isn't there now - the /etc/X11 directory exists but there is no xorg.conf at all. I checked this on two different systems running Ubuntu 18.04, and there is no xorg.conf on either of them! Is there perhaps a sample xorg.conf I should use with this setting in it? I never really knew much about xorg.conf to start with and I think the last time I had to tweak it was back in Ubuntu 12.04 or thereabouts and truthfully I don't remember much of anything about it. EDIT: Also I just remembered that back then I was running nVidia graphics, now my Intel-based system has VAAPI graphics so it would probably not be the same procedure even if I could remember it.
(2018-09-28, 20:41)fritsch Wrote: [ -> ]Refresh your browser cache ... "Intel VAAPI howto with Leia v18 nightly based on Ubuntu 18.04 server" - This howto was done by more than 250 thousand users. You don't seem to become one of them.Well no, because as I said before this is not applicable to my setup. Again I am running Ubuntu 18.04 desktop. When you look at that complicated howto, it tells you to install on Ubuntu server, and then as part of the instructions you install openbox which is a desktop environment which is used when you launch Kodi. That's not what I have or want - I am running the standard Ubuntu Desktop which in 18.04 already includes the Gnome desktop, and in previous versions included the Unity desktop. I don't really want to have to give up a decent desktop just to be able to run Kodi, and never had to do so in the past - Kodi always ran fine in Ubuntu 16.04 and previous (well, with occasional crashes at startup but otherwise it ran fine and no dropped frames!). That is why in my first post I asked specifically if there any guides to achieving PERFECT playback on Kodi 18 running Ubuntu 18.04 desktop version as the OS, on systems with VAAPI graphics? I had seen the guide you are talking about and maybe more than 250 thousand users have done it, but that still doesn't mean it is applicable to people who want to use a stock Ubuntu desktop system.
(2018-09-29, 08:23)FernetMenta Wrote: [ -> ]Make sure you have TripleBuffer disabled in xorg.conf. This is enabled by defaultI don't have triple buffer disabled on current intel hardware. No frame drops at all ....
(2018-09-30, 20:15)boba23 Wrote: [ -> ]Which does not change the fact that kodi sync works best if you use double buffering. But: if you don't have an issue, don't fix it :-)(2018-09-29, 08:23)FernetMenta Wrote: [ -> ]Make sure you have TripleBuffer disabled in xorg.conf. This is enabled by defaultI don't have triple buffer disabled on current intel hardware. No frame drops at all ....
