Full Version: How do i get the path of a specivic shortcut (script skinshortcuts)
How do i get the path of a specivic shortcut (script skinshortcuts)? (just the pure path without the "ActivateWindow")
all i was able to get was "ActivateWindow(Videos,MovieTitles,return)" or "ActivateWindow(10025,"library://video/movies/recentlyaddedmovies.xml/",return)" via
xml:
$INFO[Container(9001).ListItemAbsolute(0).Property(path),]
(Container 9001 holds the submenu)
all i would need is something i could use as dynamic content.
Is it may possible to use the override.xml to add another property which would hold only the path of an item (ListItem.path)?
Regards
Did read thru almost the whole documentation, and i just didnt find a solution (may do to my limited Englisch knewledge).
EDIT:
Never minde: "List" is the property i was looking for.
