Hi Guys,
I want to know from where I can change this value "31976":
<param name="DialogHeaderLabel" value="31976" />
Because I am working in custom dialog box and need to change the header with variable values.
Thanks for all
By changing 31976 to "My new awesome label"? ^^ (that makes it hardcoded and not able to translate)
31976 just tells the skin to use the translated language string with ID 31976 from the skin provided languages.
But I didn't find 31976 number in language file!
I don't want to change it manually
I want to know where is the source of 31976 ID because I am thinking to change it from source
If you change it from source, it's going to be changed to all other skin elements that are using the same string. That's a bad idea.
Anyway:
Look at the skin directory. There is a language folder and you have to change the master language (EN). Translations will break automatically, because the don't fit to it anymore.
But I didn't find 31976 ID number in any of languages file string.po ! Is there any source file can have this ID or it's built in?
what about this value "1"
<param name="DialogHeaderId" value="1" />
what does it mean?
It gives the control the ID "1".
Take a look at the skinning manual, some dialogs have predefined controls that are going to be filled by a plugin or Kodi core. Things like a label could be overwritten in this case.
As I said, changing the string itself is the wrong approach.
"sualfred" @
Yes thanks I understand it now.
But I have another question I created a dialog and need to change the label of it automatically depends on the values comes from my scripts addon:
<control type="label" id="my brother">
<description>header label</description>
<left>40</left>
<top>20</top>
<width>570</width>
<height>30</height>
<font>font13_title</font>
<label>here I need to attach it with my addon scripts value</label>
<align>center</align>
<aligny>center</aligny>
<textcolor>selected</textcolor>
<shadowcolor>black</shadowcolor>
</control>
for example if value string = "from my brother room" then the label in dialog will write "from my brother room"
How can I achieve this situation ?
So if my addon script.py has this conditions:
if data == "101":
xbmc.executebuiltin('ActivateWindow(1199)')
elif data == "102":
xbmc.executebuiltin('ActivateWindow(1122)')
I want the label in Window 1199 to be "From my brother" for example! and if activate 1122 the label will be " come from my father room"
