2019-04-04, 12:40
Wow, that works great! Quitting Kodi is much faster as well.
Even on my 2010 mini with patched version of Mojave.
Thanks for the solution.
(2019-04-04, 12:40)McView Wrote: [ -> ]Wow, that works great! Quitting Kodi is much faster as well.
(2019-04-04, 10:54)kernelitto Wrote: [ -> ]SOLVED ! finally !
Quit Kodi
Go to Mac preferences > Mac Security Preference Pane > Confidentiality > Accessibility
Remove all Kodi entries
Restart Kodi and cancel the message warning for allow kodi manage accessibility prefs
Kodi is so fast at start now.
Quote:Accessibility
Shows apps that run scripts and system commands to control your Mac. Deselect the app if you want to prevent it from controlling your Mac.
(2019-04-04, 10:54)kernelitto Wrote: [ -> ]SOLVED ! finally !It's ok, but do I have to do this every time?
Quit Kodi
(2019-08-31, 13:44)Iwanche Wrote: [ -> ]This is a permanent solution.(2019-04-04, 10:54)kernelitto Wrote: [ -> ]SOLVED ! finally !It's ok, but do I have to do this every time?
Quit Kodi
Is there some permanent solution?
