(2020-11-01, 07:12)fritsch Wrote: [ -> ] (2020-10-30, 09:30)mamachan Wrote: [ -> ] (2020-10-29, 21:35)fritsch Wrote: [ -> ]Just a reminder: Without a Debug Log no help is possible.
"mamachan
Senior Member
#1,212Yesterday, 10:02
i upgraded to fritschfiretv version 18.9, but now the HD audio streams no longer work (I tested 2 DTS-HD MA files that play as normal DTS).
Could someone please remind me wich are the exact settings?"
Before post debug log i'd try to solve myself.
Probably i change some settings and i don't remember
FireTV 4K does not support DTS-HD MA, it never did. You will hear the DTS Core only. This did not change, it never was different. Only DTS-HD-HR is supported by its firmware.
I'm a bit confused.
With your latest build, how i can get HD audio (Pass-Thr or LPCM)? with which audio streams and with which settings?
So I have a problem with the 4k Firestick running the latest version of Leia (18.8 I think).
How can I stop the artifacting? it's really really bad. It will sometimes be green and sometimes it will just kinda freeze the video feed for a second while the entire screen is artifiacted and then the video will resume.
It's really, really annoying. Anyone have a fix?
My tv is a TCL 4k Roku smart tv, 65" with a sony 4k reciever hooked up with ARC
(2020-11-02, 19:19)vipermaus Wrote: [ -> ]So I have a problem with the 4k Firestick running the latest version of Leia (18.8 I think).
What media are you playing and what is the source of that media?
Unedited logs are also very useful (near vital) in helping diagnosis of these kind of issues.
(2020-11-02, 20:44)noggin Wrote: [ -> ] (2020-11-02, 19:19)vipermaus Wrote: [ -> ]So I have a problem with the 4k Firestick running the latest version of Leia (18.8 I think).
I'll work on the logs, but it's just standard 1080p and 720p x264 video
(2020-11-03, 08:48)vipermaus Wrote: [ -> ] (2020-11-02, 20:44)noggin Wrote: [ -> ] (2020-11-02, 19:19)vipermaus Wrote: [ -> ]So I have a problem with the 4k Firestick running the latest version of Leia (18.8 I think).
Local USB storage, WiFi, Cabled Ethernet, NFS, SMB ?
Low bitrate x264 re-encodes or original h.264 rips from Blu-ray?
Interlaced TV or progressive?
(2020-11-04, 02:05)noggin Wrote: [ -> ] (2020-11-03, 08:48)vipermaus Wrote: [ -> ] (2020-11-02, 20:44)noggin Wrote: [ -> ]What media are you playing and what is the source of that media?
It is standard encodes, medium bit rate, cable ethernet through the amazon adapter. progressive rips. NFS from a NAS on a gigabit ethernet
"7.1 Dolby TrueHD and DTS-HD MA will be decoded to 7.1 LPCM audio and output"
Sorry, but with latest build i'm no longer able to get LPCM
I ignore all your posts, as long as you don't post a
Debug Log.Check it myself:
Input:
Quote:11-06 13:34:22.082 9481 9592 I android.media.AudioTrack: AUDIOINFO: audio_input: format: 4 sample_rate: 48000 channels: 6 AudioAttributes: AudioAttributes: usage=1 content=2 flags=0x0 tags= bundle=null
11-06 13:34:22.067 9481 9481 W Thread-5: type=1400 audit(0.0:576): avc: denied { read } for name="u:object_r:dolby_prop
0" dev="tmpfs" ino=12518 scontext=u:r:untrusted_app
0:c512,c768 tcontext=u:object_r:dolby_prop
0 tclass=file permissive=0
11-06 13:34:22.084 9481 9592 E libc : Access denied finding property "dolby.dma.minbufcnt"
11-06 13:34:22.084 9481 9592 D AudioTrack: min buf count is limited to 2 times HAL buf
11-06 13:34:22.084 292 16329 I DolbyAudioStreamOut: getLatency() Total latency:167ms (Downstream:84ms, DMA:158ms, tuning:-75ms, tuningBT:0ms), input format:0x1, sink:0x400, UxOutSetting:0, CurOutFormat:0xa000000
11-06 13:34:22.084 292 16329 D AudioFlinger: min buf count is limited to 2 times HAL buf
11-06 13:34:22.086 9481 9592 D AudioTrack: Client defaulted notificationFrames to 2566 for frameCount 7700
11-06 13:34:22.110 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
11-06 13:34:22.131 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
11-06 13:34:22.173 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
11-06 13:34:22.185 9481 13543 I MediaCodecLogger: [ASAP] HW.video.avc Got First Frame Render 173755869
11-06 13:34:22.185 9481 13543 I MediaCodecLogger: App uses Timestamps for AVSync
11-06 13:34:22.195 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
11-06 13:34:22.226 251 251 I hwcomposer: [DP] layer[334] use MDP: 0
11-06 13:34:22.238 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
11-06 13:34:22.259 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
11-06 13:34:22.301 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
11-06 13:34:22.323 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
11-06 13:34:22.366 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
11-06 13:34:22.389 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
11-06 13:34:22.429 292 13584 D AudioSPDIF: EAC3 mStreamType = 0, mSubstreamID = 0
What is 4:
https://developer.android.com/reference/..._PCM_FLOAT <- Float
What are they doing with it:
Quote:11-06 13:34:23.598 292 13583 I Node : dolby-audio-meter, AdapterPcmOut adapter audio meter: channel 0; audio level: 0.109
11-06 13:34:23.598 292 13583 I Node : dolby-audio-meter, AdapterPcmOut adapter audio meter: channel 1; audio level: 0.125
11-06 13:34:24.019 1193 1581 D Vizzini:MediaSessionLib.MediaSessionControllerStateMgr: Playback State Changed org.xbmc.kodi
11-06 13:34:24.020 1193 1581 D Vizzini:MediaSessionLib.MediaSessionControllerStateMgr: Playback State Changed org.xbmc.kodi
11-06 13:34:24.020 733 944 V Avrcp : MediaController playback changed: PlaybackState {state=3, position=1654, buffered position=0, speed=1.0, updated=173757702, actions=-1, custom actions=[], active item id=-1, error=null}
11-06 13:34:24.153 292 13583 I Node : dolby-audio-meter, AdapterPcmSystem adapter audio meter: channel 0; audio level: 2.000
11-06 13:34:24.153 292 13583 I Node : dolby-audio-meter, AdapterPcmSystem adapter audio meter: channel 1; audio level: 0.050
11-06 13:34:24.153 292 13583 I RendererNode: dolby-audio-meter, Renderer renderer audio meter: channel 0; audio level: 0.041
11-06 13:34:24.153 292 13583 I RendererNode: dolby-audio-meter, Renderer renderer audio meter: channel 1; audio level: 0.041
11-06 13:34:24.153 292 13583 I RendererNode: dolby-audio-meter, Renderer renderer audio meter: channel 2; audio level: 0.000
11-06 13:34:24.153 292 13583 I RendererNode: dolby-audio-meter, Renderer renderer audio meter: channel 3; audio level: 0.000
11-06 13:34:24.153 292 13583 I RendererNode: dolby-audio-meter, Renderer renderer audio meter: channel 4; audio level: 0.000
11-06 13:34:24.153 292 13583 I RendererNode: dolby-audio-meter, Renderer renderer audio meter: channel 5; audio level: 0.000
They pipe it through their dolby dd+ encoder ... sad. With older firmware you could get LPCM if you chose Float as input, now they reencode it to DD+. Nothing we can do about it.
I thank you for your patience but .......
1) I don't know how to create a debug.log file, I have no keyboard or other accessories besides the Firestick remote control
2) you are assuming that everyone has the same preparation as you. I apologize but personally I did not understand anything you wrote or posted above.
Sorry.
Regards.
I infact assume that one can click on this link:
Debug Log and follow the instructions. Yes, this is what I assume.
Though - as shown above - amazon seems to have changed the firmware. Now they also reencode Float multi channel under the hood to DD+ as shown in the log.
(2020-11-06, 21:43)fritsch Wrote: [ -> ]Though - as shown above - amazon seems to have changed the firmware.
Yep, my 4K stick had to do a restart a few days ago which it hasn't done in a long time.
(2020-11-06, 21:43)fritsch Wrote: [ -> ]I infact assume that one can click on this link: Debug Log and follow the instructions. Yes, this is what I assume.
It's crazy that Amazon market a lossless HD Music service that their own Fire TV Sticks struggle to output in a lossless manner...
Can you try it? And provide and adb logcat output?
(2020-11-07, 11:25)fritsch Wrote: [ -> ]Can you try it? And provide and adb logcat output?
I can confirm.
I must use Heos instead Amazon music app of the Firestick to get full HD music
