Full Version: How to get KODI 17.6 working with HD homerun HDHR3-DT
Hi all,
        New to Kodi.
I have a HD Homerun HDHR3-DT, which I have previously used with Windows media centre.
I have grabbed the Kodi add-on - and found it doesn't work and is not supported as per Add-on:HDHomeRun (wiki)
I have tried HDHomeRun simple as well - with no success. Searching this forum for HDHR3-DT yielded no results... so hence my post here.
Is there a way to get this older tuner working with Kodi ?
Not at this time.  I have an addon that I'm currently writing, and if time permits I will support the HDHR3 devices with it.  But that's a secondary goal and this functionality will not be present in the first release.
hi Buddy
I've got the same tuner than you, works well with Kodi
I use two pc but i think you can do it with just one
Use WMCserveur, then go to Kodi configure and activate PVR WMC Client
That it Smile)
(2019-01-20, 05:52)pupop Wrote: [ -> ]hi Buddy
That it Smile)
Well, that does require WMC, which is a dying breed.  I'm glad to hear it works for you for the time being.
SD claims that they improved the RF circuitry on the modern devices, but I don't think that's really the case.  The HDHR3 devices work very well.
