Full Version: Scraper not working (error 401)
for beggining, excuse me for my english level.
I use Kodi Krypton with my OC2 Box (LibreElec). I've got metadata.themoviedb.org in version 5.1.3.
The scrapper are not working now. When i check the log file ".kodi/temp/kodi.log", i've got error 401.
I try new version of metadata.themoviedb.org 5.1.4 but the result is the same.
13:19:31.721 T:545315651808   ERROR: CCurlFile::Open failed with code 401 for https://api.tmdb.org/3/movie/429727/cast...87005ddfe8
13:19:31.721 T:545315651808   ERROR: Run: Unable to parse web site
13:19:31.889 T:545315651808   ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 401
13:19:31.890 T:545315651808   ERROR: CCurlFile::Open failed with code 401 for https://api.tmdb.org/3/movie/429727/rele...87005ddfe8
13:19:31.890 T:545315651808   ERROR: Run: Unable to parse web site
13:19:32.064 T:545315651808   ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 401
13:19:32.065 T:545315651808   ERROR: CCurlFile::Open failed with code 401 for https://api.tmdb.org/3/movie/429727?api_...anguage=en
13:19:32.065 T:545315651808   ERROR: Run: Unable to parse web site
13:19:32.451 T:545315651808   ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 401
13:19:32.451 T:545315651808   ERROR: CCurlFile::Open failed with code 401 for https://api.tmdb.org/3/configuration?api...87005ddfe8
Have you got any ideas ?
Thansk a lot.
@dawnslayer
We need the full log thanks. Make sure you have v5.1.4 installed for TheMovieDB scraper. Follow these instructions to ensure the log is created correctly...
  1. Enable Debugging mode. Go to Settings>System Settings>Logging and it should be the first option
  2. Restart Kodi
  3. Replicate the problem. In your case, try to scrape one of your movies.
  4. Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link back here.
