if the PC which the Backend is installed (and running) on, is off, and therefore cant be reached, Kodi crash.
Log
EDIT:
Debug Log with component Loggin "PVR" enabled /EDIT
crashlog only tells
php:
Thread 52080 (process 46328)
# 0
(hope i picked the right crash log as there are several..)
Hello @
ksooo
Not shure, but this might be one for you.
Regards.
(2018-10-14, 08:55)Rantanplan-1 Wrote: [ -> ]Hello @ksooo
Regards.
Could be a problem with the mediaportal add-on as this works with other add-ons. Hard to tell without a stack trace of the crash.
You should ask in the respective forum section or open a Github ticket for the add-on.
(2018-10-14, 13:20)Martijn Wrote: [ -> ]See
Thanks, will wait for a reply regarding the other crash szenario (may also backend related, dont knew), and open a issue.
