Full Version: Programm, add-on for drawing lines (whiteboard)
Hello, I just would like to know if there is somewhere a programm or add-on available which makes possible to draw lines (on a white background) per touchscreen. (multitouch up to 5 finger would be very appreciate).
similar to follow link below, please note: the link can only be tested with smartphones, as it needs a touchscreen.
http://www.repaa.net/draw.html 6
so is very simple…
If that is not available, is there somebody that could program that for me? And what will be the cost?
thank you very much
