Full Version: Pi Kodi Netflix
I am not sure if this is the correct board for this, but regardless it seems to be the best suited for the question. I have my hands on a Pi 3 (the one with the metal ihs) its flash uses Raspbian with Kodi 18. I attempted to use a netflix addon(https://github.com/asciidisco/plugin.video.netflix) I was able to install it and Kodi accepted it. That is until you try to run it where an error prompts you that its broken and to check the log. (Don't know where the log is stored)
Is there any chance at fixing this problem and where would the log file be located?
The logs are usually /home/pi/.kodi/temp/kodi.log and /home/pi/.kodi/temp/kodi.old.log.
