Whenever Kodi starts up, is there any way to configure it to start in a particular spot?
For example, I would like Kodi to always automatically go to Videos > Files.
If that setting exists already, I have not been able to find it.
Use
autoexec.py (wiki) and add the following
xml:
import xbmc
xbmc.executebuiltin('ActivateWindow(Videos,sources://video/,return)')
I think some skins also have a configuration setting for this.
(2018-10-12, 20:20)Karellen Wrote: [ -> ]Use autoexec.py (wiki) and add the following
xml:
import xbmc
That sounds interesting. I'll have to read up on autoexec.py.
(2018-10-12, 21:56)DarrenHill Wrote: [ -> ]I think some skins also have a configuration setting for this.
I was pretty sure I had this set in the past. Maybe it was Confluence.
xml:
import xbmc
So, do I need to install anything to get 'autoexec.py' to run, or is it already built into Kodi (just drop a text file in the UserData folder)?
Ready to run. Kodi searches for that file at startup
Under Estuary and Confluence/Xonfluence it's in settings > interface > startup > start window
That can start in videos, but not videos > files.
(2018-10-12, 15:45)jp2code Wrote: [ -> ]For example, I would like Kodi to always automatically go to Videos > Files.
(2018-10-13, 08:57)DarrenHill Wrote: [ -> ]Under Estuary and Confluence/Xonfluence it's in settings > interface > startup > start window
But that does not give the option to get to
Videos>Files. The closest option is Videos, so the user still has to scroll and select to get where s/he wants to be.
Yup, as I noted in parallel whilst you were posting
Just wanted to add where the option is in the skins for anyone else who might want something similar.
I'm running Kodi from the Microsoft Windows 10 Store. Instead of this path:
WindowsStart - type %APPDATA%\kodi\userdata - press <Enter>
I found it here (after doing a search and not realizing it was in the wiki
https://kodi.wiki/view/Userdata):
Windows UWP %LOCALAPPDATA%\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalCache\Roaming\Kodi\
I created a Text file with this content:
xml:
import xbmc
Saved the file in the "...\Roaming\Kodi" folder, renamed it to "autoexec.py", and launched Kodi.
It didn't work.
Did I miss a step?
For now, I'm running what DarrenHill pointed out. That gets me pretty close.
The location and file structure look right, but I'm not sure the arguments in ActivateWindow are right.
See
Window_IDs (wiki) for more details, maybe videos instead of Videos for example? The pages and links from them might help.
(2018-10-14, 16:38)jp2code Wrote: [ -> ]It didn't work.
Did I miss a step?
I just tested it on Win10 v17.6 and it works here. It took me straight into my list of Sources.
xml:
Should be saved in
xml:
Windows UWP %LOCALAPPDATA%\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalCache\Roaming\Kodi\userdata
Has to be saved
in the Userdata folder, not
where the Userdata folder is saved. Same place where guisettings.xml, sources.xml and others are saved
Great. I'll mark this solved.
Thread marked solved.
