2018-10-14, 13:39
Good morning everyone
There was a web radio station I was listening to for the last ~3 years. Yesterday, that station closed down, forever. On kodi, I used a pls file that simply played the stream when it was opened inside kodi, and it only had a single entry, the one for that radio station.
I found a new radio station and I decided to make a new pls or m3u file like before and add it to kodi. Here are the contents of the m3u file
and the contents of the pls file I created
But all my kodis (info on signature) fail to play both of them. The files were tested with mpv, mplayer, deadbeef, vlc and foobar2k and they play like they are supposed to, so I assume there is not an issue with them but with kodi. So here is what kodi's log says when it fails to open one of them
And the same thing happens when I add ".mp3" to the end of the url, just in case, like so
Any ideas?
$ cat test1.m3u
#EXTM3U
#EXTINF:0,boombox.com.gr
http://stream.radiojar.com/n4n9x10yzd5tv
$ cat test2.pls
[playlist]
NumberOfEntries=1
File1=http://stream.radiojar.com/n4n9x10yzd5tv
Title1=boombox.com.gr
Length1=-1
14:03:50.360 T:139887894599232 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
14:03:50.413 T:139887894599232 ERROR: Open - error probing input format, http://stream.radiojar.com/n4n9x10yzd5tv
14:03:50.413 T:139887894599232 ERROR: Init: Error creating demuxer
14:03:50.413 T:139887894599232 ERROR: CAudioDecoder: Unable to Init Codec while loading file http://stream.radiojar.com/n4n9x10yzd5tv
14:03:50.413 T:139887894599232 WARNING: PAPlayer::QueueNextFileEx - Failed to create the decoder
14:03:50.413 T:139887894599232 ERROR: Playlist Player: skipping unplayable item: 0, path [http://stream.radiojar.com/n4n9x10yzd5tv]
http://stream.radiojar.com/n4n9x10yzd5tv.mp3
Any ideas?
