Hello,
I use Kodi 18 Leia (18.0-BETA3 Git:20180911-83d2d3c5d0-dirty Media Center Kodi).
When I choose to Show information one a movie, the movie starts playing, I never get informations.
You'd have to post a debug log.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
I've found my error, while I was trying to copy paste the debug log, I've seen that I had a mistake in the host hosting the kodi Database, after fixing this issue, everything is working as exepected !
I'm sorry for opening this post before digging in the log as I should have done... Thx for helping me anyway.
No problems. Great that you were able to solve it.
Thread marked solved.
