2018-10-18, 22:28
After watching some TV episodes, the episode's "watched" flag appears in the list view, but after navigating away from the episode's directory then returning, the "watched" flag is gone. This only happens for some series, usually those that have been on the system for a long time. If I remove the series from the library and re-add it, the problem no longer occurs.
This is happening on a stock installation of LibreElec (Krypton) 8.2.5 on a Raspberry Pi 2B, but also occurred with a previous OSMC installation (Jarvis & Krypton) on the same RPi, and also on a Windows 10 PC. All machines use a shared MySQL 5.5.59 Kodi database running under Raspbian on a separate RPi 3B, which is doing double duty as a Samba server for my media files. Since the issue occurs on multiple Kodi clients on different machines and architectures, I'm guessing that something is misfiring with MySQL.
I'm seeing an update query in the log for the files table (below) which seems to be working, but don't see any similar queries for the episode_view table (which seems to be where the episode's playCount and lastPlayed are saved), either for episodes that save or don't properly save the "watched" state.
No nonstandard Kodi add-ons are in play.
Does anyone have any suggestions for further troubleshooting? I've cleaned the library, dumped, dropped, re-created and reloaded the MyVideos107 database from the dump file, and can't think of anything else to try.
Pastebin: https://paste.kodi.tv/lipelakozi.kodi
14:07:08.396 T:2676 DEBUG: CSaveFileStateJob::DoWork - Saving file state for video item smb://RASPBERRYPI/Television/Frasier/Season 2/S02E17 - Daphne's Room.avi
14:07:08.416 T:2676 DEBUG: CSaveFileStateJob::DoWork - Marking video item smb://RASPBERRYPI/Television/Frasier/Season 2/S02E17 - Daphne's Room.avi as watched
14:07:08.424 T:2676 DEBUG: Mysql execute: update files set playCount=3,lastPlayed='2018-10-18 14:07:08' where idFile=20960
