2018-10-19, 16:26
Hi
I'm trying to enable ALSA on raspbian stretch.
/etc/asound.conf contain some ALSA plugins:
This file is symlinked to /etc/asound.rc and /home/pi/.asoundrc
Kodi 18 installed from "deb http://pipplware.pplware.pt/pipplware/di...ain/binary" repository
My /usr/share/kodi/system/advancedsettings.xml
I'm try to set:
<audiodevice>ALSA:default</audiodevice>
<audiodevice>ALSA:mainfilter</audiodevice>
<audiodevice>ALSA:ok</audiodevice>
<audiodevice>ALSA:plug:mainfilter</audiodevice>
<audiodevice>ALSA:plug:ok</audiodevice>
<audiodevice>ALSA:@</audiodevice>
It's not work for me. No sound or error "ERROR: CAESinkALSA::InitializeHW - Unable to find a suitable output format"
Kodi started in terminal emulator by command: "AE_SINK=ALSA kodi"
aplay -L :
"Aplay" tests is successfully passed:
"aplay -D ok 1k.wav" and "aplay -D default 1k.wav"
What else can I do?
pcm.!default {
type plug
slave.pcm "mainfilter";
ctl.!default {
type hw card 0
pcm.ok {
type plug
pcm.mainfilter {
type ladspa
slave.pcm "plughw:0,0";
path "/usr/lib/ladspa";
plugins [
id 1197
label mbeq
input {
# min="-70" max="30"
# 50Hz 100Hz 156Hz 220Hz 311Hz 440Hz 622Hz 880Hz 1250Hz 1750Hz 2500Hz 3500Hz 5000Hz 10000Hz 20000Hz
controls [ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ]
# controls [ -6 -3 0 0 3 4 5 6 3 0 0 0 3 4 6 ]
id 1403
label dysonCompress
input {
# Peak limit (dB) ; Release time (s) ; Fast compression ratio ; Compression ratio
controls [ -9.0 0.5 2 4 ]
id 1913
label fastLookaheadLimiter
input {
# Input gain (dB) -20 -> +20 ; Limit (dB) -20 -> 0 ; Release time (s) 0.01 -> 2
controls [ 20 0 0.8 ]
<?xml version="1.0" encoding="UTF-8"?>
<advancedsettings>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<memorysize>31457280</memorysize>
</cache>
<audiooutput>
</audiooutput>
</advancedsettings>
aplay -L :
null
Discard all samples (playback) or generate zero samples (capture)
default
ok
mainfilter
sysdefault:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
dmix:CARD=ALSA,DEV=0
Direct sample mixing device
dmix:CARD=ALSA,DEV=1
bcm2835 ALSA, bcm2835 IEC958/HDMI
dsnoop:CARD=ALSA,DEV=0
Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=0
Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=0
Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1
What else can I do?
