Full Version: A single channel broadcast channel is not showing up from nextPVR backend
I have a Hauppage quadTV tuner installed in my computer with nextPVR. Kodi is connected to the nextPVR backend and most channels show up and work perfectly. There is a single channel however that is visible and watchable in the backend that does not show up in the kodi guide. if I set up recordings in ext PVR, the recordings are viewable in kodi, but I can't find or select the channel from Kodi. Is there a way to manually add a channel or some other way to fix this problem?
Thread moved to nextPVR section
