if I install the Estuary Mod v2 skin, will I lose the 'Libreelec' section from the settings?
TIA.
No, & you can always go back to the default Estuary
This is something you should ask the
Estuary Mod v2 maintainer - it would be easy enough to add support in the same way as stock Estuary.
