Full Version: Up Next
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Oh. I thought it was from a playlist with different episodes.
Which, btw, doesn't work when I enable "work with playlists." I have a couple of smart playlists with episodes from different shows, but it plays the next episode from the library, instead of the playlist.
(2019-01-12, 03:10)adun79 Wrote: [ -> ]
(2019-01-10, 17:05)mardukL Wrote: [ -> ]Hi, first thanks to bring that to a new level.
I miss 2 info properties ("mpaa", "videoresolution")
, i could adjust it to my skin, and i rellay missed those 2 :-)
The show that is playing doesn't look like Game of Thrones. What's the catch, why are they different shows?
Just a shot from dev mode, so the dialog choosen will pop up imediatly a video is started.No matter which content, supreme for testing and adjust the "window dialog"
Firsr test shots here, but not fully optimized (skin will use 3, to choose from)
Stilll there
Still there simple
Up next fancy
Up next simple
"additional" fancy (choose via skinsetting)
But good start
Any idea what I need to do if I am getting a Python dependency error when installing?
Thanks for the addon!
Would be great if you can add resolution & mpaa Smile
Thanks for this great addon
I,m using with CoreELEC - Kodi 18 RC4
My problem is when I click the "watch now" button. It starts well the next episode, but starts with a new countdown message with the full duration of the new episode.
Is there anyway to fix it?
thanks in advance
Hello,
small French translation if interested
https://uptobox.com/d71nzo6nchia
I'm having serious problems getting this to work on leia (18.1)..
I'm running 2 different distros (Libreelec and OSMC) both the latest available Leia versions. Both connect to a MySQL back end.
Libreelec :
Correctly identifies next episode and plays but only once, the second time it identifies it, counts down then goes back to the menu.
Does not work with Smart Playlists.. identifies next episode but never plays.
OSMC :
Correctly identifies next episode and plays but only once, the second time it identifies it, counts down then goes back to the menu. The video it plays freezes the first frame for 10 seconds.. the audio continues. then the video stops and the video catches up and all is fine.
I've uninstalled, reinstalled, rebooted... i'm sure the audio catch up bit is an OSMC problem and not the plugin, but i've not had it occur any other time than way Up Next initiates a video to play.... Any ideas what's going on?
@danmedhurst Please remove or reduce your signature image to 40px height as per the forum rules.
https://kodi.wiki/view/Official:Forum_rules#Signatures
All done, sorry.. it was a very old signature.
@im85288 Link to Dutch translation. Can you add it to your addon please?
https://www.dropbox.com/s/qipibmjxd7lt3n...gs.po?dl=0
(2019-01-12, 23:39)mardukL Wrote: [ -> ]
Stilll there
Still there simple
Up next fancy
Up next simple
But good start
A much better layouts. great work   Smile
(2019-02-09, 01:42)Blurayx Wrote: [ -> ]
(2019-01-12, 03:10)adun79 Wrote: [ -> ]The show that is playing doesn't look like Game of Thrones. What's the catch, why are they different shows?
Stilll there
Still there simple
Up next fancy
Up next simple
But good start
I much better layouts. great work   Smile
Finished layouts a while back.
Could use custom colors, en/disable "upnext countdown" image, and en/disable diffuse over thumb.
3 layouts , for each (simple ans fany)
watch gallery
(2019-02-09, 10:51)mardukL Wrote: [ -> ]
(2019-01-12, 23:39)mardukL Wrote: [ -> ]Just a shot from dev mode, so the dialog choosen will pop up imediatly a video is started.No matter which content, supreme for testing and adjust the "window dialog"
Stilll there
Still there simple
Up next fancy
Up next simple
But good start
watch gallery
Where can I get this version?
(2019-02-12, 03:09)Blurayx Wrote: [ -> ]
(2019-02-09, 01:42)Blurayx Wrote: [ -> ]I much better layouts. great work   Smile
watch gallery
It's not another addon version.
Its the skinning part for that addon,which is edited for the skin itself.
so that's the layouts and settings for 'upnext' in my 'titan mod' skin.
