2018-10-23, 11:18
Good morning at all,
i write here because recently i'm facing a lot of problems about audio Visualization using the last development build of Kodi Leia (updating it every day) on platform Windows.
I tried before to search about solutions but without any kind of success...so i will try to write it here the problems in order to understand better if there's some kind of solution or if i'm the only one with those kind of problems but let's go in order and make a list.
Problems with Shadertoy:
-sometimes the presets list is empty
-i notice that the presets names are not all the presets that are actually into the addon directory (i can't see in the list AudioEclipse for example)
-when i turn on the visualization instead of see it working (and it worked in some previous build of leia) i see like a portion of xml code (projected specular in vertical so upside down) or a big icon like the one about settings
-settings tab of the visualization are empty
Problems with Vortex:
-vortex preset list is empty
-i can't see any visualization running
Hope in some kind of help and i thank you already for any answer
Best Regards
Best Regards
