2018-10-23, 20:20
I've posted similar problems but thought I'd start over with all of the information in one place. Fell free to move this to the proper place if I posted in the wrong place. I'm running Leia Beta 3.
The problem happens when zap2epg is running under the following circumstances (it may happen with other addons but I can repeat this with zap2epg):
1) The Shield Goes to sleep.
2) The Shield screensaver comes on.
3) I remove focus from Kodi (or whatever it is called when I hit the Shield home button).
I get booted out of Kodi when any of the the above items occur while zap2epg is running with the "spinning circle" on the screen.
I get the following error in the Kodi log file:
ERROR: eglSwapBuffers failed (EGL error 12288)
Zap2epg won't run if I try to start it using Chron under the above circumstances. It runs fine otherwise.
When zap2epg starts the Kodi "spinning circle" remains on the screen. However if I hit exit the spinning circle stops and I can continue using Kodi as normal but the background process is still running. If any actions occur at this point that would normally cause Kodi to crash (I.e., let the Shield go to sleep) Kodi doesn't crash and zap2epg continues to run. I was initially hoping to use this as a work-around but I can't figure out to get the process to start while the Shield is asleep.
I've posted the problem on the Shield TV forum and the moderators believe it is a Kodi problem.
Below is a link to the log file:
https://paste.kodi.tv/zetatevele.kodi
Thanks for any help
Edit: Added clarification to the problem.
Thanks for any help
