Hi everybody
since kodi 18 beta 4 my substitute path for sources.xml not working anymore.
am i alone with this problem ? no one talk about this in the forum
thank you
There's a note in the wiki to say pathsubs for sources are broken and won't be fixed.
I'm not sure exactly what's broken, as mine still work.
If the sources.xml is on a password protected share then it's unlikely to work anymore, if you want to continue to do use a shared sources.xml then you'll have to put it on an share with no password protection.
(2018-10-30, 14:12)jjd-uk Wrote: [ -> ]If the sources.xml is on a password protected share then it's unlikely to work anymore, if you want to continue to do use a shared sources.xml then you'll have to put it on an share with no password protection.
i have no password on my shares...
I've found this but only on the Windows build. If I run on Libreelec it's fine. Realised this was happening when my library scan started prompting for missing sources.
Same issue. Still existing with 18.RC1. Windows 6 Android builds.
<pathsubstitution>
<substitute>
<from>special://masterprofile/sources.xml</from>
<to>nfs://192.168.1.250/_kodi/sources.xml</to>
</substitute>
</pathsubstitution>
I need an alternative to pathsubstitution, because I am using Kodi shared PC/Android TV/Android Tablets.
Scanning the library and changing sources on the PC and sharing it to all devices (incl. MySYL DB) is essential to me.
An alternative could be:
<system>
<sourcepath>nfs://192.168.1.250/Videos/_kodi</sourcepath>
</system>
(2018-11-30, 17:11)palindrom Wrote: [ -> ]I need an alternative to pathsubstitution, because I am using Kodi shared PC/Android TV/Android Tablets.
<system>
</system>
How often are you changing sources, and why? I'm trying to understand why you'd need to do that often enough for it to be a pain.
Edit: and what the heck is a Windows 6 Android build
Quote:How often are you changing sources, and why? I'm trying to understand why you'd need to do that often enough for it to be a pain.
Its just more annoying than anything as I have 4 devices all sharing the same central DB etc. If I add/update/amend a source on one machine and then clean happens to run on another, all the content on the path is wiped out until the next import is run. So not critical clearly but a pain and was how I found it when a chunk of my library disappeared.
(2018-12-01, 13:03)jeffski10 Wrote: [ -> ]Quote:How often are you changing sources, and why? I'm trying to understand why you'd need to do that often enough for it to be a pain.
You only need a sources.xml on one machine. Use that one machine to update/clean/amend your database(s) and all the others will automatically see the changes. Anything else just makes it more complicated and more prone to issues like you are seeing. It's pointless (from my point of view) to run a library clean on (for instance) an android tablet when your PC will be faster and better equipped to handle the load.
Agree on the fact that all updating has to occur on one machine - I've seen doubles in the library otherwise. I tend to now just use FreeFileSync to make sure the latest files are on all clients so I don't need them centrally any more.
so you think i can delete sources.xml on the "slave" kodi ?
(2019-01-09, 22:07)dkangel Wrote: [ -> ]so you think i can delete sources.xml on the "slave" kodi ?
Rename it, restart Kodi, and find out.
kodi.log illustrates why path substitution won't work for sources.xml. Message
NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
occurs before processing of special://xbmc/system/advancedsettings.xml and special://profile/advancedsettings.xml
15:22:11.147 T:139916419999872 NOTICE: -----------------------------------------------------------------------
15:22:11.147 T:139916419999872 NOTICE: Starting Kodi (18.0-RC5 Git:18.0rc5.2-Leia). Platform: Linux x86 64-bit
15:22:11.147 T:139916419999872 NOTICE: Using Release Kodi x64 build
15:22:11.147 T:139916419999872 NOTICE: Kodi compiled 2019-01-16 by GCC 8.2.0 for Linux x86 64-bit version 4.19.14 (267022)
15:22:11.147 T:139916419999872 NOTICE: Running on LibreELEC (official): 8.95.003 9.0, kernel: Linux x86 64-bit version 4.19.14
15:22:11.147 T:139916419999872 NOTICE: FFmpeg version/source: 4.0.3-Kodi
15:22:11.147 T:139916419999872 NOTICE: Host CPU: AMD E-350 Processor, 2 cores available
15:22:11.147 T:139916419999872 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
15:22:11.147 T:139916419999872 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
15:22:11.147 T:139916419999872 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
15:22:11.147 T:139916419999872 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
15:22:11.147 T:139916419999872 NOTICE: special://envhome/ is mapped to: /storage
15:22:11.147 T:139916419999872 NOTICE: special://home/ is mapped to: /storage/.kodi
15:22:11.147 T:139916419999872 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
15:22:11.147 T:139916419999872 NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
15:22:11.147 T:139916419999872 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
15:22:11.147 T:139916419999872 NOTICE: Local hostname: LibreELEC
15:22:11.148 T:139916419999872 NOTICE: Log File is located: /storage/.kodi/temp/kodi.log
15:22:11.148 T:139916419999872 NOTICE: -----------------------------------------------------------------------
15:22:11.156 T:139916419999872 INFO: loading settings
15:22:11.157 T:139916419999872 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:22:11.190 T:139916419999872 DEBUG: CSkinSettings: no <skinsettings> tag found
15:22:11.190 T:139916419999872 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:22:11.191 T:139916419999872 DEBUG: CMediaSourceSettings: Setting <default> source to : tvrecordings
15:22:11.198 T:139916419999872 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
15:22:11.198 T:139916419999872 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="utf-8" ?>
<advancedsettings>
<cputempcommand>/usr/bin/cputemp</cputempcommand>
<gputempcommand>/usr/bin/gputemp</gputempcommand>
<showexitbutton>false</showexitbutton>
<remotedelay>1</remotedelay>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<video>
<latency>
<delay>0</delay>
<refresh>
<min>23</min>
<max>24</max>
<delay>175</delay>
</refresh>
</latency>
</video>
</advancedsettings>
15:22:11.198 T:139916419999872 WARNING: CSettingsManager: missing version attribute
15:22:11.200 T:139916419999872 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
15:22:11.201 T:139916419999872 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<pathsubstitution>
<substitute>
<from>special://profile/keymaps/</from>
<to>smb://sat.lan/KodiClient/userdata/keymaps/</to>
</substitute>
<substitute>
<from>special://profile/sources.xml</from>
<to>smb://sat.lan/KodiClient/userdata/sources.xml</to>
</substitute>
<substitute>
<from>special://profile/addon_data/</from>
<to>smb://sat.lan/KodiClient/userdata/addon_data/</to>
</substitute>
</pathsubstitution>
</advancedsettings>
15:22:11.201 T:139916419999872 DEBUG: Configuring path substitutions
15:22:11.201 T:139916419999872 DEBUG: Registering substitution pair:
15:22:11.201 T:139916419999872 DEBUG: From: [/storage/.kodi/userdata/keymaps/]
15:22:11.201 T:139916419999872 DEBUG: To: [smb://sat.lan/KodiClient/userdata/keymaps/]
15:22:11.201 T:139916419999872 DEBUG: From: [/storage/.kodi/userdata/sources.xml]
15:22:11.201 T:139916419999872 DEBUG: To: [smb://sat.lan/KodiClient/userdata/sources.xml]
15:22:11.201 T:139916419999872 DEBUG: From: [/storage/.kodi/userdata/addon_data/]
15:22:11.201 T:139916419999872 DEBUG: To: [smb://sat.lan/KodiClient/userdata/addon_data/]
