2018-10-31, 23:52
First off, much praise to the dark theme ALL HAIL THE DARK THEME!!!, and tMM in general, its spectacular, much thanks to the developers!!
Second, would an admin please change my user name to KodiThomson50, it is on many other sites, it is my first name, and unfortunately including "kodi" in a username upon selection flags inadequacy. Pending, thanks to Karellen, name change request made on this name change request thread: 237108 (thread)
Third, this is a thread, which indicates the issues I have found, I am a newbie, I do not have answers, so please do not post your issues as well!!!
Fourth, I'll update the top post with solutions to each issue, or a quote from devs regarding each issue, as best I can, have time for, or feel like in general.
Fifth, said solutions may break things, I'm not responsible for your problems created by trying to implement my solutions much the same as anyone responding to this thread is not responsible to what I do with their shared information, that being said, if someone mentions something that breaks things, call them out on it please, nicely.
Sixth, these are NOT necessarily problems, as some may point out (appreciated), but more of little issues, caveats, minor bugs, or small inconsistencies.
Seventh, I explain things in far too much detail sometimes. sorry...
Eighth, I have not searched the forums, have not searched the wiki, have not read much of the help, mostly just done a LOT of trial-and-error experimentations in the last 15 hours its been out.
Ninth, where's the "code" option in this forum? is it the "source" entry? Newbie question. Found it, its [ c o d e ] [ / c o d e ] (without spaces) all good.
Tenth, I mostly just lurk through all the help, documentation, wikis, then experiment, create more problems, and try to remember how I've got to some conclusions, often forgetting, lol, trying as best I can to not let my issues or problems become others' problems. Ergo the reason I've not signed up to this forum in the past, despite using XBMC since v12 or so? I've probably done some things wrong here, haven't read the forum rules yet, might do, if there's a problem just say I should read them and I will. As far as things I can't change, well, admins where y'all at!?! jks.
Eleventh, If you need me to recreate an issue or need more information regarding one, please request it. If I see the notification a response will likely follow.
1) 2.9.13 allowed for video format (eg "720p") to be marked as a variable in the renamer options of the "Season Folder" options. 3.0 does not. This was great for having say a 1080p version of a show, and a 360p version for archival purposes, along side the HD.
I am intending on seeing "Adventure Time (2010) S01 [360p]" as a folder name, but upon rename/cleanup, the " [360p]" is disregarded, leaving only "Adventure Time (2010) S01" as the folder name.
Though is available in the file name using:
Shows "Adventure Time (2010) - S01E01 - Slumber Party Panic [h264-360p].mp4" properly.
Final Desired output:
I can provide the 2.9.13 renamer settings upon request (they were different, but the desired result worked)
2) I have a few recommendations for the strings/values used for the menus, based upon what each menu item does, a little more clarity perhaps, but I will post them in a bit.
3) Not a problem, Year-based seasons (such as on shows with 50+ years of seasons, like looney toons (sp?), BBC Documentaries (1936), etc), when using two-digit season numbers in renamer options, thank you for not cutting the season to two digits, from four, (example: if BBC Documentaries S2012 were cut it would appear as S20 or S12 or something therefore it would all become messed up). Thank you for making sure that did not happen.
4) Recommendation: On the OpenSubtitles scraper options, please add the following entry boxes (that function), something like "Only request _____ number of subtitles in ____ hours", and "Only search missing subtitles", and perhaps a "Remember what has been searched" so that if your first 200 missing subs are searched, and nothing comes back, the next day it starts searching from 201, rather than 1 again. And perhaps a sensor that detects when you've requested too many, and prevents further requests from being made and thereby prevents being blocked by them.
5) Recommendation: Option to lock a specific show to a specific scraper, disregarding default settings, and disregarding "force best match", or an option to EXCLUDE or IGNORE a specific scraper for a specific show. If for example, a show has inconsistencies across databases, such as Invader Zim (2001), on TVDB vs IMDB vs TheMovieDB, Trakt, and OpenSubtitles, OMDB, etc, some show as having six seasons, each around 10-15 episodes, and some show the original airdates with the first season being 36 or 42 episodes while second season has 10 or 12 with no remaining seasons. Depending on what scraper you use you can seriously mess up some things. The option to ignore information that is specifically wrong in this instance would be magnificent.
6) Recommendation: Scrape favorability, per show. Favor "Episode Name" vs "S01E01" when scraping. Some scrapers have different information than in my library, and I may know that a specific show has all the proper names on the episodes, regardless of what season or episode they show up in (for example that Invader Zim series again, episodes are named properly, but differentiate between scrapers regarding their episode numbers.) I would prefer that a scraper search for metadata using the "Episode Name" portion of the file name, rather than the (Incorrect depending on which scraper used) "S01E01" portion of the file name.
7) Option for custom XML generation or export? I'd like to create something similar to what MediaCenterMaster has for my WesternDigitalTeleVision box I have, exporting specifically created XML for WDTV.
8) Future OpenSubtitles.org Uploader option? I have several shows or seasons I've converted to other formats and would like to mass-upload subs for. Others that I've used GoogleSpeachRecognition API to transcribe (with 4/10 word accuracy, 9/10 timing accuracy) using scripting, some 3000 shows I'd rather not do one-by-one. A method to do this would be to display all shows subs have been acquired for, select them, have tMM search OS.org for the hash of each the shows and their subs (also store this hash in the db), and if OS doesn't have them, upload them using some predetermined settings.
9) Using a folder to drop media into (eg, called "__IMPORT__"), within the same root directory as your show names, ends up being erroneously (though understandably) interpreted as a show title "import", say four shows were dropped into this directory, each with about 25 episodes, the show "import" shows up, with 100 episodes that can't be matched to anything. I'm afraid the scraper may misinterpret things before I have a chance to sort them out. Is there a way to specify a "Import from here" folder, or a "watched" directory, to keep separate form the polished library?
${showTitle} (${showYear}) S${seasonNr2} [${videoFormat}]
${showTitle} (${showYear}) - S${seasonNr2}E${episodeNr2} - ${title} [${videoCodec}-${videoFormat}]
Show Folder: ${showTitle} (${showYear})
Season Folder: ${showTitle} (${showYear}) S${seasonNr2} [${videoFormat}]
File Name: ${showTitle} (${showYear}) - S${seasonNr2}E${episodeNr2} - ${title} [${videoCodec}-${videoFormat}]
