(2018-11-04, 05:05)Klojum Wrote: [ -> ] (2018-11-03, 22:22)Stile35 Wrote: [ -> ]Is there any problem with 60fps playback in Kodi for H.264?
Provide full MediaInfo details of your stuttering video files. Do those h264 files also have 10bit coloring?
It is 8bit coloring. MX Player plays those files just fine. I don't know why Kodi doesn't.
MediaInfo of 4K 60fps H.264:
General
Complete name : I:\Serije\20181102_221946.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42)
File size : 70.0 MiB
Duration : 8 s 171 ms
Overall bit rate : 71.8 Mb/s
Encoded date : UTC 2018-11-02 21:19:55
Tagged date : UTC 2018-11-02 21:19:55
xyz : +45.7392+016.0192/
com.android.version : 8.0.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 1 frame
Format settings, GOP : M=1, N=60
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 8 s 98 ms
Source duration : 8 s 102 ms
Bit rate : 72.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 60.000 FPS
Minimum frame rate : 47.949 FPS
Maximum frame rate : 68.545 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.145
Stream size : 69.7 MiB (100%)
Source stream size : 69.7 MiB (100%)
Title : VideoHandle
Language : English
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : BT.601
Matrix coefficients : BT.2020 non-constant
mdhd_Duration : 8098
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 255 KiB (0%)
Title : SoundHandle
Language : English
MediaInfo of 4K 60fps H.265 which plays fine:
General
Complete name : I:\Serije\20181103_203127.mp4
Format : MPEG-4
File size : 165 MiB
Duration : 32 s 659 ms
Overall bit rate : 42.3 Mb/s
Encoded date : UTC 2018-11-03 19:32:00
Tagged date : UTC 2018-11-03 19:32:00
xyz : +45.7391+016.0193/
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile :
[email protected]@
main
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Source duration : 32 s 671 ms
Bit rate : 42.0 Mb/s
Minimum frame rate : 34.522 FPS
Maximum frame rate : 68.285 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.084
Stream size : 164 MiB (99%)
Source stream size : 164 MiB (99%)
Title : VideoHandle
Language : English
mdhd_Duration : 32659
Codec configuration box : hvcC
Audio
Format : AAC LC
Duration : 32 s 619 ms
Bit rate : 256 kb/s
Stream size : 1 019 KiB (1%)
Title : SoundHandle
Language : English
