Full Version: Incompatible with HDHomeRun add-on
I'm using Kodi 18.0 beta 5 with Grid and everything works great except for the HDHomeRun add-on. The add-on runs, but there are left-over elements all over the screen that stop me from using Grid. Switching to any other skin does not show these elements. The elements that should NOT be showing is the giant green HDHomeRun logo in the middle of the screen, the playback bar, and the grey icon in the bottom right. The TV Guide is also inaccessible - it should be accessible by pressing up or down or right.
Example showing the issue: https://i.imgur.com/EailHot.png
Found out the HDHomeRun addon was not fully v18 compatible. The update that has not been pushed to the add-on repository has fixed it.
See: https://forum.silicondust.com/forum/view...hp?t=69506
Update: https://www.dropbox.com/s/gfflpnhbp3rc8d...1.zip?dl=0
