Full Version: Only fmt-3.0.1 builds successfully ... is this to be expected?
Kodi's build deps include fmt versions 3.0.1, 4.1.0, and 5.1.0, but I am only able to build 18.0b5 for Linux (x86_64) using fmt-3.0.1.  Is this to be expected?
[100%] Linking CXX static library libkodi.a
[100%] Built target libkodi
Scanning dependencies of target kodi
make[2]: *** No rule to make target 'build/lib/libfmt.a', needed by 'kodi-x11'.  Stop.
make[2]: *** Waiting for unfinished jobs....
[100%] Building CXX object CMakeFiles/kodi.dir/xbmc/platform/posix/main.cpp.o
make[1]: *** [CMakeFiles/Makefile2:1132: CMakeFiles/kodi.dir/all] Error 2
make: *** [Makefile:141: all] Error 2
Link to complete build log: https://gist.github.com/graysky2/18b8444...ff5ace4e5e
Here is my cmake stanza:
cmake -DCMAKE_INSTALL_PREFIX=/usr \
-DCMAKE_INSTALL_LIBDIR=/usr/lib \
-DENABLE_EVENTCLIENTS=ON \
-DENABLE_INTERNAL_FFMPEG=ON \
-DENABLE_INTERNAL_FMT=ON \
-DENABLE_INTERNAL_CROSSGUID=ON \
-DENABLE_INTERNAL_FSTRCMP=ON \
-DENABLE_INTERNAL_FLATBUFFERS=ON \
-Dlibdvdcss_URL="/libdvdcss-1.4.2-Leia-Beta-5.tar.gz" \
-Dlibdvdnav_URL="/libdvdnav-6.0.0-Leia-Alpha-3.tar.gz" \
-Dlibdvdread_URL="/libdvdread-6.0.0-Leia-Alpha-3.tar.gz" \
-DFFMPEG_URL="/ffmpeg-4.0.3-Leia-Beta5.tar.gz" \
-DFMT_URL="/fmt-5.1.0.tar.gz" \
-DCROSSGUID_URL="/crossguid-8f399e8bd4.tar.gz" \
-DFSTRCMP_URL="/fstrcmp-0.7.D001.tar.gz" \
-DFLATBUFFERS_URL="/flatbuffers-1.9.0.tar.gz" \
-DENABLE_AIRTUNES=OFF \
-DENABLE_AVAHI=OFF \
-DENABLE_BLUETOOTH=OFF \
-DENABLE_CEC=OFF \
-DENABLE_OPTICAL=OFF \
-DENABLE_SMBCLIENT=OFF \
-DENABLE_SSH=OFF \
-DENABLE_UPNP=OFF \
-DENABLE_VDPAU=OFF \
../"xbmc-18.0b5-Leia"
Interestingly, if I use fmt 5.1.0 externally (ie installed on the build system) and remove the cmake options to use the internal version, it builds just fine.  Bug?
EDIT: https://github.com/xbmc/xbmc/issues/14829
If you enable internal fmt, you have to use our version, since we only tested the build for this.
(2018-11-08, 22:33)wsnipex Wrote: [ -> ]If you enable internal fmt, you have to use our version, since we only tested the build for this.
 I understand, but the web site hosts three different versions: http://mirrors.kodi.tv/build-deps/sources/?C=N&O=A
So?  We can add 20 more. Doesn't mean we publicly endorse them. It might only be there for testing purpose.
Only whats in the github code is what we want you to use
Thanks @Rechi PR#14830 worked.
