Full Version: on Fedora 29 - PGS subtitle
Hi !
I upgraded to Fedora 29 on my intel ivybridge and it's currently Kodi 18 beta 4 packaged with it.
PGS subtitles aren't displaying correctly. I can only see rectangles...
Another problem is samba connections within Kodi who don't work anymore with my Freenas while it was working with previous version of Kodi.
I resolved it by mounting shares directly under Fedora at boot
Do I miss doing something ?
Thank you !
David
You may find it more useful to post questions to the RPMFusion mailing list.
The fix for Samba is currently in updates-testing. The update to beta 5 has not been pushed to updates-testing yet, but it will be pushed in a day or two.
Samba fix:
dnf --enablerepo=rpmfusion-free-updates-testing update kodi\*
(kodi-18.0-0.15.b4.fc29)
Beta 5:
http://koji.rpmfusion.org/koji/buildinfo?buildID=9367
(kodi-18.0-0.16.b5.fc29)
I have a separate question for you.
Can you play a video that has a large aspect ratio? Something that would have black bars on your screen.
Do you see pieces of your Kodi skin left as artifacts in the black bars?
I only see this on my Ivy Bridge system and I cannot reproduce it on any other system.
I didn't notice skins problems when i tried it.
I came back to Fedora 28 - Kodi 17.6 for more constancy.
my problems are reproducible under a virtual machine with virtualbox
I've found what the problem was :
Intel accelerated video need libva-intel-driver rpm to be installed.
https://www.rpmfind.net/linux/rpm2html/s...api-driver
or
sudo dnf install libva-intel-driver
David
