For some reason whenever I try to play the OGM movies(while running StreamServer before hand) in Divvin, I always get the "playplistplayback aborted" error.
I'm running the latest T3CH build (rev 13120) and have on real idea what's wrong
Can anyone help me out? I'm getting the latest T3CH build right now and I'm going to give that a shot right now and hope that might fix my dilemma.
Here's the debug log:
http://pastebin.com/m7963cb88
Hello, you are using a very old build of that plugin get the new one from my site.
The version that you are using doesn`t pass the urls to the server at all.
Hence the error.
It tells you that when you try and access the OGM section.
from your logfile:
"OGM+MOVIES+-+Listed%2C+but+not+supported+yet%2CVoinage.')"
http://code.google.com/p/voinage-xbmc-plugins/
Get the new version of Hagens veoh proxy it has been revamped also.
http://veohproxy.googlecode.com/files/VeohProxy.zip
Happy viewing Fluffy.
Cheers Voinage.
That did the trick....thanks Voinage!!!
Hi there,
I have the script in place and can stream (albeit with much buffering) the DivX movies. I'm assuming that the Flash and OGM's will play back with less buffering but I *ALWAYS* get the error:
Too many consecutive failed attempts
Is this something I am doing or is there a problem somewhere else?
I should also say that I downloaded the latest version of the plugin from your site. ;-)
post a log so i can see whats going on.
Look in your xbmc folder.
Heya,
I don't know what it is that I have done but I am now able to view OGM's (Perfectly) and DivX's (Subject to a lot of buffering) but am still unable to play the FLV's at all.
In addition, some of the other Plugins which used to work for me (for example the NinjaVideo plugin) are now not playing back and are throwing the same error message out about 'Too many failed consecutive items'. I am running the latest Streamplug server posted on this board and the 1.2 version of Veohproxy.
Is the logfile you want XBMC.LOG??
Oh... and my XBMC version is:
XBMC-SVN_2008-05-18_rev13120
Hi all! Wow, I don't even know where to start. I am so amazed at the hard work that goes into open source projects such as XBMC, and another favorite of mine, Frets on Fire (rock on!)... Anyway, I have tried a few different flavors of XBMC (Windows, Linux (Ununtu 8.04), and the USB Key version.....) All have their own little quirks, (which I'm sure are user error!), but I am currently focusing on the windows build. I am trying to add the DivVin video plugin, and I swear I am doing everything I am supposed to, but to no avail...
System is WinXP SP3, XBMC 14125, StreamPlug Server script, and the DivVin plugin... Here is what I have done so far....
Install XBMC
Setup a few shares to my media (MP3's, DIVX, .JPGS), alll local. So far so good, though struggling with the Video_TS folders as I am moving from VMC with MyMovies to XBMC..
Extracted the StreamPlug script to the Scripts folder.
Extracted the DivVin plugin to the Video Plugins folder
Started XBMC.....go to Scripts, execute default1.py in the StreamPlug folder.
XBMC hangs, and then crashes..
Any help??
Here's a part of the log that might help??
-------------------------------19:47:52 T:1540 M:1636212736 DEBUG: CGUIMediaWindow::GetDirectory (C:\Program Files\XBMC\scripts)
19:47:52 T:1540 M:1636212736 DEBUG: ParentPath = []
19:47:52 T:1540 M:1636032512 DEBUG: CFileItemList::Sort, sorting took 0 millis
19:47:53 T:1540 M:1631969280 DEBUG: Clearing cached fileitems [C:\Program Files\XBMC\scripts\StreamplugServer\]
19:47:53 T:1540 M:1632874496 DEBUG: CGUIMediaWindow::GetDirectory (C:\Program Files\XBMC\scripts\StreamplugServer\)
19:47:53 T:1540 M:1632874496 DEBUG: ParentPath = [C:\Program Files\XBMC\scripts]
19:47:53 T:1540 M:1633087488 DEBUG: CFileItemList::Sort, sorting took 0 millis
19:47:54 T:1540 M:1633116160 INFO: initializing python engine.
19:47:54 T:1540 M:1633112064 DEBUG: LoadLibraryA('python24.dll')
19:47:54 T:1540 M:1631907840 DEBUG: LoadLibrary('python24.dll') returning: 03B70B50
19:47:54 T:1540 M:1631903744 DEBUG: dllGetProcAddress(00C1E298(kernel32.dll), 'InterlockedCompareExchange') => 7C809832
19:47:54 T:1540 M:1631830016 DEBUG: GetModuleFileNameA(00000000, 04632490, 256) => 'xbmc.xbe'
19:47:54 T:1540 M:1631830016 DEBUG: advapi32.dll fake function RegQueryInfoKeyA called
19:47:54 T:1540 M:1631744000 DEBUG: LoadLibraryExA called with flags:
- LOAD_WITH_ALTERED_SEARCH_PATH
19:47:54 T:1540 M:1631744000 DEBUG: LoadLibraryA('zlib.pyd')
19:47:54 T:1540 M:1631604736 DEBUG: LoadLibrary('zlib.pyd') returning: 03B70BE0
19:47:54 T:1540 M:1631604736 DEBUG: dllGetProcAddress(01880000(zlib.pyd), 'initzlib') => 01882150
19:47:54 T:1540 M:1630482432 DEBUG: new python thread created. id=1
19:47:54 T:496 M:1630470144 DEBUG: thread start, auto delete: 0
19:47:54 T:496 M:1630466048 DEBUG: Python thread: start processing
19:47:55 T:1540 M:1630617600 DEBUG: CGUIMediaWindow::GetDirectory (C:\Program Files\XBMC\scripts\StreamplugServer\)
19:47:55 T:1540 M:1630617600 DEBUG: ParentPath = [C:\Program Files\XBMC\scripts\StreamplugServer\]
19:47:55 T:1540 M:1630498816 DEBUG: CFileItemList::Sort, sorting took 0 millis
19:47:55 T:496 M:1630294016 INFO: -->Python Interpreter Initialized<--
19:47:55 T:496 M:1629011968 DEBUG: LoadLibraryExA called with flags:
19:47:55 T:496 M:1629011968 DEBUG: LoadLibraryA('_socket.pyd')
19:47:55 T:496 M:1628913664 DEBUG: Unable to resolve ordinal ws2_32.dll 51
19:47:55 T:496 M:1628913664 DEBUG: LoadLibrary('_socket.pyd') returning: 035A2028
19:47:55 T:496 M:1628913664 DEBUG: dllGetProcAddress(018A0000(_socket.pyd), 'init_socket') => 018A4BF0
19:47:55 T:496 M:1628909568 DEBUG: LoadLibraryExA called with flags:
19:47:55 T:496 M:1628909568 DEBUG: LoadLibraryA('_ssl.pyd')
19:47:55 T:496 M:1627930624 DEBUG: LoadLibrary('_ssl.pyd') returning: 03B459D0
19:47:55 T:496 M:1627930624 DEBUG: dllGetProcAddress(04650000(_ssl.pyd), 'init_ssl') => 04651820
19:47:55 T:496 M:1627500544 DEBUG: dllGetProcAddress(00C1E640(advapi32.dll), 'CryptAcquireContextA') => 00468690
19:47:55 T:496 M:1627500544 DEBUG: dllGetProcAddress(00C1E640(advapi32.dll), 'CryptGenRandom') => 004686A0
19:47:55 T:496 M:1627131904 DEBUG: dllbind: family:2 port:64652 ip:127.0.0.1
19:47:55 T:496 M:1627131904 DEBUG: LoadLibraryA('ws2_32')
19:47:55 T:496 M:1627131904 DEBUG: LoadLibrary('ws2_32.dll') returning: 00C1E4A0
19:47:55 T:496 M:1627131904 DEBUG: dllGetProcAddress(00C1E4A0(ws2_32.dll), 'getaddrinfo') => 0046DC70
19:47:55 T:496 M:1627131904 DEBUG: dllGetProcAddress(00C1E4A0(ws2_32.dll), 'getnameinfo') => 0046DC90
19:47:55 T:496 M:1627131904 DEBUG: dllGetProcAddress(00C1E4A0(ws2_32.dll), 'freeaddrinfo') => 0046DCC0
19:47:55 T:496 M:1627131904 ERROR: ws2_32.dll: Unresolved function called (51), Count number 1
19:47:55 T:496 M:1627127808 ERROR: security_error, code 1
19:47:55 T:496 M:1627127808 DEBUG: kernel32.dll fake function ExitProcess called
19:47:55 T:496 M:1627119616 FATAL: EXCEPTION_BREAKPOINT (0x80000003)
at 0x018a54e8-----------------------------------------
Not intended as a "bump", but have tried the NinjaVideo plugin, and the script I needed for that one too, crashes my XBMC...
my plugins are designed for xbox xbmc - i do not, at the moment, build them to run cross platform.
I simply do not have the time at the moment to fix bugs for a system that i never intended it to run on or is at least 98% stable.
Sorry.
Hope someone who uses xbmc for windows can help try posting in that section.
Darn! And from what I've read, you've done a lot!!! Thanks for your contributions!
So I have MUCH to learn about the interoperability of XBMC and it's plugins... I honestly thought (shame on me), that the core application was platform specific, but the plugins/scripts were interoperable between ports....
Oh well. It's a shame, because much of the attraction of XBMC for me was based on the plugins that you created!!!
Thankyou for your kind words, and i truly am sorry - but time is limited at the moment.
I will add that the stremplug server that you are runnin is version 0 beta.
Please download :- Veoh proxy 1.3 from unbehagens google code page.
Also download the latest versions of all my plugins from the google code page in my sig.
I think that most of your faults will go away.
