2018-11-09, 09:42
@Wanilton - Thanks for your and MarcoQui's hard work.
I noticed this thread - v18 - RFC: Extended artwork type naming .
So basically, I can currently find no final definitive answer for how to name my artwork filenames, the Wiki for example is based on MQ7 (?) and contradicts other sources sometimes. My current file names are based on what worked in V17 - MQ7.
But since Artwork Downloader isn't with us anymore... I have no idea what to do. Go with Artwork Beef's file-naming? Kodi 18's current standard (whatever it is)? Or maybe stay with the MQ7\Artwork Downloader standard? Or maybe @Karellen 's tables?
Will MQ8 support the same file-naming that worked in MQ7? Will it use a current standard? Which one if so?
I know this is a transition period to V18 and things are a bit fluid, but any help on the matter would be very much appreciated.
Have an awesome weekend everyone! Thanks for any suggestion you might provide.
