Full Version: TVDB does not scrape TV Shows
https://paste.kodi.tv/kuyenehahu
House of Cards, or for that mather any show. I've been using XAM, but for that one I get 30 years old BBC Short series. I've found that TVDB allowes you to select the correct one on refresh but it does not get any TV show info...
Running on OpenELEC (official) - Version: 8.0.4,
F.Y.I., OpenELEC hasn't been developed for over 1.5 years now, and therefore misses vital system updates as well as addon updates for today's Kodi workings. It's unlikely it will ever see any new updates.
We recommend you switch over to LibreELEC, which is a OpenELEC "fork", and very much up-to-date.
Seemed like there were no new updates for a while now :-)
I actualy went there to check for new version before asking a question here...
That problably means I need to setup kodi from the scratch?
Updated with same / new problem :-)
https://paste.kodi.tv/ubijeqofob
what I have on drive is this:
https://www.imdb.com/title/tt1856010/?ref_=fn_al_tt_1
What is detected is this:
https://www.imdb.com/title/tt0098825/?ref_=fn_al_tt_2
I have found that there is a way to select correct entry where there are multiple, but can't seem to stumble upon that?
Ham, and just before sending this, I experimented with adding 2013 to the folder name and it worked...
Thank's for instructions on how to upg to libreELEC
Rename your folder to House of Cards (2013).  Then it should grab the right one automatically.  If there's multiple shows with the same name, it never hurts to include the year.
Always check the tvdb naming first.
