I don't know what you're getting at, but I executed the above command and the newly created file jerks as well
ffmpeg -i Test.avi TestNEW.avi
ffmpeg version 4.0.1 Copyright © 2000-2018 the FFmpeg developers
built with gcc 7.3.1 (GCC) 20180710
configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth
libavutil 56. 14.100 / 56. 14.100
libavcodec 58. 18.100 / 58. 18.100
libavformat 58. 12.100 / 58. 12.100
libavdevice 58. 3.100 / 58. 3.100
libavfilter 7. 16.100 / 7. 16.100
libswscale 5. 1.100 / 5. 1.100
libswresample 3. 1.100 / 3. 1.100
libpostproc 55. 1.100 / 55. 1.100
Input #0, avi, from 'Test.avi':
Duration: 00:01:48.68, start: 0.000000, bitrate: 2049 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 720x400 [SAR 1:1 DAR 9:5], 1752 kb/s, 25 fps, 25 tbr, 25 tbn, 25 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, fltp, 123 kb/s
Stream #0:2: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, fltp, 123 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (mpeg4 (native) -> mpeg4 (native))
Stream #0:1 -> #0:1 (mp3 (mp3float) -> mp3 (libmp3lame))
Press [q] to stop, [?] for help
Output #0, avi, to 'TestNEW.avi':
Metadata:
ISFT : Lavf58.12.100
Stream #0:0: Video: mpeg4 (FMP4 / 0x34504D46), yuv420p, 720x400 [SAR 1:1 DAR 9:5], q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc
Metadata:
encoder : Lavc58.18.100 mpeg4
Side data:
cpb: bitrate max/min/avg: 0/0/200000 buffer size: 0 vbv_delay: -1
Stream #0:1: Audio: mp3 (libmp3lame) (U[0][0][0] / 0x0055), 48000 Hz, stereo, fltp
Metadata:
encoder : Lavc58.18.100 libmp3lame
frame= 2717 fps=451 q=24.8 Lsize= 7051kB time=00:01:48.72 bitrate= 531.3kbits/s speed=18.1x
video:5172kB audio:1698kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 2.633497%
