Hi
After updating to Kodi 18 beta5 on my Android, I can't timeshift the current recording, I can only pause and stop, I cant forward o backwards
Is anyone having the same issue..
It was working with Kodi 17.6
Thank you
Yes, I am seeing the same on Raspberry Pi but not on Windows.
Not tested on Android, but can do later.
So maybe it's a Kodi 18 general issue and not of the plugin ?
(2018-11-15, 14:12)Iosub Wrote: [ -> ]So maybe it's a Kodi 18 general issue and not of the plugin ?
No, since the recent Kodi 18 builds on Windows work fine.
Well then it's a general issue with Android..
Let's see if the developer fix it
(2018-11-16, 23:16)Iosub Wrote: [ -> ]Well then it's a general issue with Android.
No, it's not just an android issue, as I see the same with Raspberry Pi libreelec builds.
I will gather logs and try to narrow down the libreelec build where this started.
(2018-11-22, 16:44)Iosub Wrote: [ -> ]Any updates on the issue @margro ?
He hasn't been online since 3rd Nov. We just have to be patient.
(2018-11-23, 09:50)mcelliott Wrote: [ -> ] (2018-11-22, 16:44)Iosub Wrote: [ -> ]Any updates on the issue @margro ?
Upsss.. sorry I didn't want to boder..
Just a quick note that I've seen this thread and that I will have a look at this. I first need to revive my Linux development setup before I can debug this.
A debug log file is still useful.
(2018-11-17, 21:22)mcelliott Wrote: [ -> ]Okay, for LibreElec test builds on Raspberry Pi, I have worked out which test build broke skip steps in running recordings.
See
https://forum.kodi.tv/showthread.php?tid...pid2792603
@margro Do you still need logs? Happy to provide them if needed.
Regards,
Mark
Looks like margro needs the logs, can you provide him? Thanks
Sorry, I switched to NextPVR.
Regards
Mark
