2018-11-14, 14:55
2018-11-14, 18:56
We don't get that many telegram-style requests for help these days...
However, we will need more information, other than the usual "it doesn't work".
How about providing a debug log (wiki)?
2018-11-14, 19:25
do not understand how upload a debug log
2018-11-14, 20:23
2018-11-18, 13:23
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
2.Restart Kodi
2018-11-23, 18:35
How to you send data from the kodi paste site
2018-11-25, 11:01
If you use the kodi log uploader add-on it will give you the url to post here.
Otherwise when you paste into the site and save it, the save button will grey out but the url in the browser bar will change to include a string of random letters at the end. That's the URL we need.
