Full Version: Netflix addon
Installed netflix addon in Kodi 18.0 Beta 5
All works fine until trying to view a Netflix movie.
Click on movie causes the rotating timing wheel to run then stop for half a second then run again for
a second or two then flashes a few bits of text on the top of the screen and then screen Netflix menu.
Video does not run.
Attached is the log file. https://paste.kodi.tv/aniqotavag.kodi
Windows 7 with up to date updates. ESET Internet Security 12.0.27.0 antivirus.
Netflix on Kodi currently has an internal problem, which is being fixed. It should be available with the next nightly build.
Also, your log file shows a banned add-on that has been installed, making you basically ineligible for support on this forum.
