I'm trying to add movies directory to my android tv version (both Shield and Sony TV).
After browsing to my NAS and defining the folder, I'm pressing OK.
The "set content" screen does NOT show up and I can't choose the content to be defined as movies and to choose scraper, it automatically get back to the video files screen.
I can still access the folder and play the movies but I can't have the Fanart information.
Thank you for your quick reply.
I'm following the instructions.
After step 6 i'm not getting step 7, it get back to step 3.
At Step 6, did you press
OK at the bottom of the box? That has the effect of locking in your selected path and then the box in Step 7 pops up.
If you did that, what path are you selecting/entering that shows in Step 6. A screenshot might be helpful.
If the image is on your computer, then use button 19. If the image has already been uploaded to a public image hosting site, then use button 14
Hi, I'm attaching the pictures.
(2018-11-16, 23:48)Karellen Wrote: [ -> ]At Step 6, did you press OK at the bottom of the box? That has the effect of locking in your selected path and then the box in Step 7 pops up.
Hello,
i have the same problem too.
i can't see picture n. 7
i am trying to import my library on NAS (MyclousEX2Ultra) to KODI
I found this post .....
https://forum.kodi.tv/showthread.php?tid...pid1756691
Is it current or has a solution been found?
thanks for your help
rossomike1966
You cannot use uPnP as a Library Source due to the limitations of DLNA sharing.
You need to set up network shares like SMB if using Windows.
(2020-07-05, 21:12)Karellen Wrote: [ -> ]@rossomike1966
Thank you very much
can you tell me where i can find information in this case?
