Full Version: Appear to be banned from forum
Tried to login today and noticed I can not access the forum under my normal username (ronvp). Any reason for that??
Just checked and it says you were online 30mins ago. No ban.
There is no ban on your ronvp account.
Are you using a VPN? It is quite possible that the IP you have been allocated has previously been banned.
Moved to Website & Forum Issues
(2018-11-17, 20:17)Karellen Wrote: [ -> ]There is no ban on your ronvp account.
No VPN and still not able to get in. Below is the message I get
Can you try it now?
I've tweaked your account settings for ronvp, as I suspect when you were upgraded to a donor one of the other categories (registered user) may have mistakenly not been set which could perhaps lead to that screen.
Just tried and it is working again Thanks for the help!  BTW, you can now close the Ronvanp account..
Good news.
My suspicion was correct - the registered flag had been missed hence the forum software thought your account hadn't been activated (item 3 in the list on the screen).
Will close the temporary account too and mark this one solved.
Thread marked solved.
