2018-11-18, 01:53
Hello,
I find tmm really good. But I have a problem with the command:
I'm back:
I tested with the versions:
- 2.9.13
-2.9.14
-3.0
But the result is the same. While with GUI it works
-update it's OK
-scrapeAll it works as well
and the movies files are renamed at the same time. there are only TV series that are not renamed.
Any ideas?
./tinyMediaManagerCMD.sh -rename
I'm back:
dje@asrock:~/Téléchargements/tmm_3.0-SNAPSHOT_d45f8c7_linux$ ./tinyMediaManagerCMD.sh -rename
2018-11-18 00:39:00,276 INFO [main] org.tinymediamanager.TinyMediaManager:158 - =====================================================
2018-11-18 00:39:00,276 INFO [main] org.tinymediamanager.TinyMediaManager:159 - === tinyMediaManager © 2012-2018 Manuel Laggner ===
2018-11-18 00:39:00,276 INFO [main] org.tinymediamanager.TinyMediaManager:160 - =====================================================
2018-11-18 00:39:00,278 INFO [main] org.tinymediamanager.TinyMediaManager:161 - tmm.version : 3.0-SNAPSHOT
2018-11-18 00:39:00,278 INFO [main] org.tinymediamanager.TinyMediaManager:162 - os.name : Linux
2018-11-18 00:39:00,278 INFO [main] org.tinymediamanager.TinyMediaManager:163 - os.version : 4.15.0-39-generic
2018-11-18 00:39:00,278 INFO [main] org.tinymediamanager.TinyMediaManager:164 - os.arch : amd64
2018-11-18 00:39:00,278 INFO [main] org.tinymediamanager.TinyMediaManager:165 - java.version : 1.8.0_191
2018-11-18 00:39:00,724 INFO [main] org.tinymediamanager.TinyMediaManager:605 - default encoding : UTF-8 | UTF8 | UTF-8
2018-11-18 00:39:00,724 INFO [main] org.tinymediamanager.TinyMediaManager:605 - set encoding to : UTF-8 | UTF8 | UTF-8
2018-11-18 00:39:00,724 INFO [main] org.tinymediamanager.TinyMediaManager:194 - System language : fr_FR
2018-11-18 00:39:00,724 INFO [main] org.tinymediamanager.TinyMediaManager:195 - GUI language : fr_FR
2018-11-18 00:39:00,944 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.album.universal.conf' - using defaults
2018-11-18 00:39:00,953 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.artists.universal.conf' - using defaults
2018-11-18 00:39:00,959 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.themoviedb.org.conf' - using defaults
2018-11-18 00:39:00,964 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.tvdb.com.conf' - using defaults
2018-11-18 00:39:00,968 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.album.universal.conf' - using defaults
2018-11-18 00:39:00,974 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.artists.universal.conf' - using defaults
2018-11-18 00:39:00,978 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.themoviedb.org.conf' - using defaults
2018-11-18 00:39:00,981 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.tvdb.com.conf' - using defaults
2018-11-18 00:39:01,138 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_fanarttv.conf' - using defaults
2018-11-18 00:39:01,170 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_opensubtitles.conf' - using defaults
2018-11-18 00:39:01,293 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_omdbapi.conf' - using defaults
2018-11-18 00:39:01,330 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_moviemeter.conf' - using defaults
2018-11-18 00:39:01,333 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_imdb.conf' - using defaults
2018-11-18 00:39:01,338 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_tmdb.conf' - using defaults
2018-11-18 00:39:01,348 WARN [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_universal_movie.conf' - using defaults
2018-11-18 00:39:01,366 INFO [main] org.tinymediamanager.TinyMediaManager:196 - Scraper language : français
2018-11-18 00:39:01,397 INFO [main] org.tinymediamanager.TinyMediaManager:197 - TV Scraper lang : français
2018-11-18 00:39:01,406 INFO [headless] org.tinymediamanager.TinyMediaManager:225 - =====================================================
2018-11-18 00:39:01,407 INFO [headless] org.tinymediamanager.TinyMediaManager:253 - starting tinyMediaManager
2018-11-18 00:39:01,465 INFO [headless] o.t.thirdparty.MediaInfoUtils:75 - Using MediaInfoLib - v17.12
2018-11-18 00:39:01,710 INFO [headless] o.tinymediamanager.core.movie.MovieList:333 - found 3 movies in database
2018-11-18 00:39:01,713 INFO [headless] o.tinymediamanager.core.movie.MovieList:354 - found 1 movieSets in database
2018-11-18 00:39:01,760 INFO [headless] o.t.core.tvshow.TvShowList:324 - found 6 TV shows in database
2018-11-18 00:39:01,768 INFO [headless] o.t.core.tvshow.TvShowList:372 - found 7 episodes in database
2018-11-18 00:39:01,859 INFO [headless] org.tinymediamanager.TinyMediaManagerCMD:345 - Commandline - rename & cleanup movies...
2018-11-18 00:39:01,862 INFO [headless] org.tinymediamanager.TinyMediaManagerCMD:506 - Commandline - rename & cleanup new shows...
2018-11-18 00:39:01,862 INFO [headless] org.tinymediamanager.TinyMediaManagerCMD:522 - Commandline - rename & cleanup new episodes...
2018-11-18 00:39:01,864 INFO [headless] org.tinymediamanager.TinyMediaManager:376 - bye bye
- 2.9.13
-2.9.14
-3.0
-update it's OK
Any ideas?
