Full Version: Error log various messages
Hi at all, i just wonder if somebody can point me at what can cause some problems.
I'm actually debugging the Xperience1080 skin so it can be that something is broken or outdated.
Let's go in order with some errors inside the LOG
 ERROR: Window Translator: Can't find window infodialog
i can't understand about what it refers, can it be because the skin is using the (script-globalsearch-infodialog.xml) and the original script doesn't use it anymore?
If this is the problem how i resolve it? simply deleting the voices about !Window.IsVisible(script-globalsearch-infodialog.xml) ? In all the skin xml the only infodialog voices are those.
WARNING: CApplication::Initialize - startup.xml taints init process
It's normal or there's something wrong inside the startup.xml?
WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
This one i have no clue, i can't find anywhere into the skin a SettingList
DEBUG: CPythonInvoker(3, E:\KODI\portable_data\addons\script.skin.helper.service\service.py): start processing
ERROR: Control has invalid animation type (no condition or no type)
This one appear some lines after load the home.xml, can it be there the problem with the animations?
P.S. There's any way to have a more verbose log able to tell me also what file or line cause the problem?
Before printing the error/warning message can be usefull add the full line or instruction that caused the problem
Thanks for any advice, best regards
(2018-11-19, 14:49)3xistence Wrote: [ -> ] ERROR: Window Translator: Can't find window infodialog
the infodialog was removed in kodi krypton, your skin is still referencing it.
not related to globalsearch in any way.
(2018-11-19, 14:49)3xistence Wrote: [ -> ]WARNING: CApplication::Initialize - startup.xml taints init process
can be ignored.
(2018-11-19, 14:49)3xistence Wrote: [ -> ]WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
can also be ignored, not skin related.
(2018-11-19, 14:49)3xistence Wrote: [ -> ]ERROR: Control has invalid animation type (no condition or no type)
there's an animation that's missing something. could be a conditional animation without specifying the condition, or the type isn't defined at all.
(2018-11-19, 14:49)3xistence Wrote: [ -> ]P.S. There's any way to have a more verbose log able to tell me also what file or line cause the problem?
nope, Debug Log is as good as it gets.
(2018-11-19, 22:02)ronie Wrote: [ -> ]
can be ignored.
Thank You Ronie for your reply and your advices!
About the infodialog, how the skin will reference to it? i searched into all the xml for something like "infodialog" but except the globalsearch- i can't find nothing more
What i must search for in order to remove any kind of references to this infodialog?
Thanks in advance
Best regards!
Skins can ship their own globalsearch xml files so you still have to change it there. Ronie just said that it has nothing to do with his own default and addon provided xml files.
(2018-11-20, 10:17)sualfred Wrote: [ -> ]Skins can ship their own globalsearch xml files so you still have to change it there. Ronie just said that it has nothing to do with his own default and addon provided xml files.
 So the problem is probably inside the very own skin globalsearch (for sure there are some files about globalsearch inside the skin directory), thank you so much to point me into the right direction to solve those problems!
I removed all the voices about infodialog as it's not needed anymore on the new Globalsearch for Leia as well as the xml itself (probably created by the skin developer).
The voice still exist inside the kodi.log and it appear instantly after loading the skin
10:52:31.749 T:5040   ERROR: Window Translator: Can't find window infodialog
10:52:31.757 T:5040 WARNING: CApplication::Initialize - startup.xml taints init process
Another strange problem that i don't know what cause it is this one:
 ERROR: NEWADDON Unknown Video Info Key "file"
I use mainly Kodi for music and easy access to my music library so there is not so much particular addons inside of it . Also the voice NEWADDON doesn't makes me understand pretty much what can cause the problem.
I don't know so much about it but i can provide every single thing on request in order to solve also this problem
