I'm on Kodi 18 beta 5 and there was a update yesterday for the skin and now it won't update. Beta 1, 2. 3, and 4 had no issues. Is this an issue with the skin or Beta 5 ??
See image on my phone screenshot.
You're not running the latest nightly build which bumped the GUI dependency.
So I have to updated to the nightly versus the beta release ??
Only if you want the latest version of Confluence.
Thanks, will do, cheers mate
Just to confirm, this issue (the dependency not being satisfied and not being able to install Confluence) is supposed to be solved in RC1? Because I have a
ticket open about RC1 crashing on start and I have the same "dependency not met" with the last nightly that starts correctly, KodiSetup-20181116. Was the change made in KodiSetup-20181117, by any chance? The error I see in the kodi.log seems to be related to DX11 (but I'm not a developer).
[edited: rephrasing]
