Full Version: Music visualizations without fanart - is it possible in Estuary?
I have been trying to get the visualizations to work without the fanart being displayed. But for some reason under setting when I switch off Fan art, the visualizations are not displayed and not sure it this expected behaviour?
In Estuary Mod it works as I would expect. So wonder if i am missing something?
It looks like the setting for music fanart in the background is separate from the media fanart in the background.  Here's what I did to turn off the music fanart:
1- start playing something and go to the music visualization screen
2- bring up the OSD (using the 'm' key on your keyboard or whatever remote button is mapped to that)
3- go to the settings gear icon on the far right to bring up the settings
4- in that area there is an option to turn off the background fanart
I suspect it works differently in the Estuary Mod mostly because (I think) that mod really just uses the look and feel of Estuary but is built from the ground up using different skin code and logic.
thanx for the bug report!
fix pending: https://github.com/xbmc/xbmc/pull/14941
Thanks Ronie, your logging of the bug report is much appreciated.
Thank you both, @RMP888 and @ronie, i was getting ready to ask this same question. Can't wait for this to make it to @Milhouse's LE dev builds.
